Objects Flying towards each other (2d kinematics)
The forum discussion centers on solving a 2D kinematics problem involving a cat and a baby launched from skeet traps at different times. The cat is launched horizontally at speed (v0/√2), while the baby is launched at speed v0 at an angle of (π/4). The participants derive equations for the horizontal and vertical motion of both objects, ultimately leading to the determination of the time difference (t_b - t_c) required for a midair collision. The final expression for this time difference is t_b - t_c = (l√2/v) / (2gl/v^2 - 1), which matches the teacher's solution.
  • Understanding of 2D kinematics equations
  • Familiarity with projectile motion concepts
  • Ability to manipulate algebraic expressions and solve equations
  • Knowledge of trigonometric functions and their applications in physics
  • Study the derivation of projectile motion equations in detail
  • Learn about the implications of launch angles on projectile trajectories
  • Explore the use of spreadsheets for simulating kinematic problems
  • Practice solving complex algebraic equations involving multiple variables
Students studying physics, particularly those focusing on kinematics, as well as educators looking for collaborative problem-solving techniques in projectile motion scenarios.
chimpfunkz
A cat and a baby are launched from skeet traps on opposite sides of the
Grand Canyon, which are at the same height and a distance ℓ apart. The
cat is launched horizontally at speed (v0/√2), the baby at initial speed v0 at
an angle of (pi/4) above the horizontal. By amazing good luck, it happens that
the cat and baby collide in midair.
For a collision to occur, the cat and the baby must have been launched at different times.
determine the time difference between the launching of the cat and the launching of the baby.
x(t)=v0*cos(θ)*t
y(t)=v0*sin(θ)*t-[gt^2]/2
I set up the equations so that h is equal for both the baby and the cat, with the baby flying for t+tprime seconds, and the cat flying for t seconds. However, this left me with a long, unsimplifiable equation. Next I tried to find h, the height at which they collide, and use that to find the distance L where they do collide. However, this left me with the problem of the gravity, which I couldn't resolve. If anyone could give me a direction of where to go, or how to set up the equations themselves, that is all I really need, and maybe even a general direction of how to proceed with the problem.
What a problem! At first reading, there seem to be way too many variables, but we must think of Vo and L as being known givens. From them, can we calculate a t' that results in a collision? When you write your Xcat = Xbaby and Ycat = Ybaby equations, you are sure on the write track. You have two equations and two unknowns, t and t'. So you can solve for t'. It is a little messy (use a large sheet of paper), but it works out without even a quadratic. In the horizontal part, did you get t = L*.707/Vo - t'/2 ? In the vertical part I have a t² term, a (t+t') term and a (t+t')² term. After subbing one into the other and squaring the binomials, I got a mess all right - 8 terms - but four of them canceled out, including the (t')² ones.
I scarcely believed my answer, so I made a spreadsheet with the x,y trajectories for both objects, given values of L, and Vo. I had it calculate the t' from L,g and Vo, and sure enough, that resulted in a collision. Slight changes in t' and there was no collision. Amazing!
OK, I had a crack at this and I think I solved it.
This is what I did ( it seems similar to your first approach, so maybe you made an algebraic mistake? ). Let's call the time of flight of the cat t_b and the time of flight of the baby t_b. I found x_c and x_b, which are the horizontal distances traveled by the cat and the baby respectively. Then I found the y_c and y_b which are the distances the cat and the baby respectively fell, and made them equal. This allowed me to find t_c in terms of t_b. Then I got another equation using the fact that x_c + x_b = l , and plugged the expression for t_c into it. The only unknown quantity remaining was t_b. So I solved for t_b and found it in terms of known quantities. Then I found t_c, and subtracted it from t_b to find t_b - t_c.
Edit: Hi Delphi51. I was actually writing out my reply when you posted, so I didn't know you posted first. Yeah, the quadratic terms canceled out in my solution too.
Let me see if I am on the right track:
y_b = v_0sin(\frac {π}{4})t_b-\frac{1}{2}gt_b
and
y_c = \frac{v_0}{√2}sin(0)t_b-\frac{1}{2}gt_c
as well as
ℓ = x_b + x_c or ℓ = v_0 cos(\frac {π} {4}) t_b + \frac{v_0}{√2}cos(0)t_c
So when I solve for t_c using the formula for length to solve for t_c, I get
t_c=\frac{ ℓ-v_0cos(\frac {π}{4})t_b} {\frac{v_0}{√2}cos(0)}
So what do I do from here? do I just plug in t_c for the y positions of the baby and cat when they equal each other? or is there something I am missing,
Yes. You just have to plug in t_c to y_{b} = y_{c}, but simplifying the expression for t_c will help a lot.
There seem to be mistakes in your y_b and y_b, which I guess are absent minded algebraic mistakes, since you have the equation for y(t) correct in your original post.
whoops! I forgot my squares! so the correct equations
y_b = v_0sin(\frac {π}{4})t_b-\frac{1}{2}gt^2_b and y_c = \frac{v_0}{√2}sin(0)t_b-\frac{1}{2}gt^2_c
But how could you simplify tc? would the simplest form just be
t_c=\frac{√2( ℓ-v_0cos(\frac {π}{4})t_b)} {v_0}
Then after this is where I get lost. I understand the concept, that is to say replacing tc with the above, but whenever I do it out on paper, I seem to get lost, or the terms don't really work well. This might be a little too much to ask, but could you show the first few steps of plugging in tc into y(t)?
You can simplify further using \cos \left( \frac{\pi}{4} \right) = \sin \left( \frac{\pi}{4} \right) = \frac{1}{\sqrt{2}}.
Everything else is the same as I did so far.
If you still have trouble I'll post how to plug in t_c.
So for Tc, t_c=\frac{√2 ℓ-v_0t_b)} {v_0}
So you plug that in for when y(t) is equal for both the baby and the cat, which is
\frac{v_0}{√2}sin(0)t_c-\frac{1}{2}gt_c= v_0sin(\frac {π}{4})t_b-\frac{1}{2}gt^2_b or, since sin(0)=0,
so plugging in Tc, you get
-\frac{1}{2}g(\frac{√2 ℓ-v_0t_b)} {v_0})^2= v_0sin(\frac {π}{4})t_b-\frac{1}{2}gt^2_b then you simplify this to get tb in terms of velocity and gravity right?
It is actually tb-tc (what you originally called t') that you want.
Recommend you replace tc with tb+t' so you can solve for t' - easier than trying to solve for tb-tc.
@chimpfunkz,
Yes, you simplify that equation to get t_b in terms of velocity and gravity. But like Delphi51 said, the final answer they ask for is t_b - t_c. After finding t_b, you can plug that into your equation for t_c to find t_c. Then subtract from t_b to find t_b - t_c.
Alright, so at long last, this is what I have:
t_b-t_c=2\frac{\frac{-gℓ}{v^2}}{ \frac{v^2-2gℓ}{√2v}} - \frac {√2ℓ}{v}<br /> <br /> <br />
The question is, what does this simplify too? What should I do to make the algebra a little easier? Would the final result of this match the answer my teacher gave for this problem, which is \frac{\frac{ℓ√2}{v}}{\frac{2gℓ}{v^2}-1}
Well, it would be if
t_b - t_c = 2 \frac{\frac{-gl^2}{v^2}}{\frac{v^2-2gl}{\sqrt{2}v}} - \frac{\sqrt{2}l}{v}
instead of what you've written,
t_b - t_c = 2 \frac{\frac{-gl}{v^2}}{\frac{v^2-2gl}{\sqrt{2}v}} - \frac{\sqrt{2}l}{v}
I had a solution on paper yesterday, but now I've lost it. Check your calculations again, and if you can't find anything wrong, I'll solve it from the beginning and see if my solution is equal to your teacher's.
You were right, I did lose the square. It is actually t_b - t_c = 2 \frac{\frac{-gl^2}{v^2}}{\frac{v^2-2gl}{\sqrt{2}v}} - \frac{\sqrt{2}l}{v}
And I know this might be a lot to ask, but could you take the formula above, and maybe explain quickly how to simplify it? Algebra is not really my strong suit.
OK, here are the steps.
First let's take this to be the subtraction of two fractions.
t_b - t_c = \frac{\frac{-2gl^2}{v^2}}{\frac{v^2-2gl}{\sqrt{2}v}} - \frac{\sqrt{2}l}{v}
If you look at your teacher's answer, it's one fraction with only one denominator, namely \frac{2gl}{v^2} - 1. So let's try to get one denominator for our expression. We can do this by multiplying both the numerator and the denominator of the left fraction by the denominator of the right fraction, and multiplying both the numerator and the denominator of the right fraction by the denominator of the left fraction. That is,
t_b - t_c = \frac{\frac{-2gl^2}{v^2}}{\frac{v^2-2gl}{\sqrt{2}v}} - \frac{\sqrt{2}l}{v} = \frac{v \frac{-2gl^2}{v^2}}{v \frac{v^2-2gl}{\sqrt{2}v}} - \frac{\frac{v^2-2gl}{\sqrt{2}v} \sqrt{2}l}{\frac{v^2-2gl}{\sqrt{2}v} v} = \frac{\frac{-2gl^2}{v}}{\frac{v^2-2gl}{\sqrt{2}}} - \frac{\frac{v^2l-2gl^2}{v} }{\frac{v^2-2gl}{\sqrt{2}}} = \frac{\frac{-2gl^2}{v} - \frac{v^2l-2gl^2}{v}}{\frac{v^2-2gl}{\sqrt{2}}}
So,
t_b - t_c = \frac{\frac{-2gl^2-v^2l+2gl^2}{v}}{\frac{v^2-2gl}{\sqrt{2}}} = \frac{\frac{-v^2l}{v}}{\frac{v^2-2gl}{\sqrt{2}}} = \frac{-\sqrt{2}vl}{v^2-2gl} = \frac{\frac{l\sqrt{2}}{v}}{\frac{2gl}{v^2}-1}
which is your teacher's answer. If you have trouble following this, let me know where and I'll elaborate.
Wow, that makes it so much clearer. The only step I don't get is how you get from \frac{-\sqrt{2}vl}{v^2-2gl} to \frac{\frac{l\sqrt{2}}{v}}{\frac{2gl}{v^2}-1}
Multiply both numerator and denominator by -1.
Then divide both by v^2.
  • · Replies 20 ·
