pmb_phy
- 2,950
- 1
Yes. And if you want to take that into account then you don't have a single particle system.JesseM said:Well, doesn't the wall of the container count as an "object"?
Pete
pmb_phy said:I'm going to have to disagree with you here pervect. While this is true for a box it is not true for a star, which has no containing wall, for which there is non-zero pressure inside.
(assuming weak fields and small boxes)
A rod under external stress is not a closed system. E/c^2 works only for a closed system
Now apply this kind of thinking for a gas with no walls. It appears to me (a hunch/guess) that to get the result I just add one p/c term for each spatial dimension. This will reduce the equation to
[tex]\rho_{active} = \rho + 3p/c[/tex]
If you take a look at Einstein's field equations in the week field limit then you'll see that this rho on the left, i.e. what I called "mass" above" will be a function of the pressure in the star.
Pete
I think you missed my point. You're referring to the entire gas-box system whereas I am referring only to the gas. Also it makes no difference as to the size of the box as to whether F/A is a tension or a pressure term.pervect said:When the box is small, though, the tension in the box walls contributes a negative term to the mass of the box which exactly cancels out the positive terms due to the pressure.
The mass of the box is not E/c^2. It is the total mass of the mass-box system that is E/c^2.In short, the pressure terms in the stress-energy tensor T11, T22, and T33 do not contribute to the mass of the box - the intergal over the entire volume is zero. This is why the mass of the box is E/c^2.
Recall the statement that I was responding to "one might wonder why the increase in the mass of the box is E/c^2 since pressure causes gravity, and the box is under pressure."I suppose I should have added that specifically the assumption that the box is an isolated system to avoid your "stressed rod" example, but that was inherent in the original problem definition.
your point being?Right. But it does work for a closed system.
The purpose of my weak field example was to help the layman since it is easier to follow. It more readily shows the relationship of the inertial mass of the gas to the active gravitational mass of the gas. If you have Schutz's new book then look up his derivation as to why the inertial mass of a gas (not box-gas, just the gas) is a function of the pressure of the gas.The answer that I have confidence in for finding the mass of a large isolated, static box (static star) with significant gravitational self-energy via a volume intergal I've posted earlier, and is from Wald...
pmb_phy said:I think you missed my point. You're referring to the entire gas-box system whereas I am referring only to the gas.
