Observables, Measurements and all that
5 replies · 2K views · last reply
spookyfw
Hi Folks,
I somehow cannot get the difference and have to admit that I am left confused.
For a probability of measuring m with the operator M on state [itex]\Psi_i[/itex]
[itex]p(m|i) = <\Psi_i| M^{+}_m M_m |\Psi_i> = <\Psi_i| M_m |\Psi_i>[/itex].
The average of an observable is defined as [itex]<O> = <\Psi_i| O |\Psi_i>[/itex].
So the measurement by M gives me a probability, the measurement with the observable an expectation value? Okay..the observables will be hermitean, the only thing I know about the measurement matrix is, that is not unitary - otherwise [itex]M^{+}_m M_m[/itex] would be equal to the unity matrix.
Is the difference that an observable doesn't change the system, but a measurement when projective projects the system into one of the states?
One last question: What is the reasoning for defining a measurement like [itex]M^{+}_m M_m[/itex] and not by M alone directly?
Thank you so much in advance..I hope the above somehow makes sense ;).
Steffen
spookyfw said:
Hi Folks,
Steffen
Let [itex]\vert \Phi_m \rangle[/itex] be a complete set of eigenstates of operator [itex]M[/itex]: (for simplicity, let's assume that the eigenstates are nondegenerate; that is, there can't be more than one state with eigenvalue [itex]m[/itex])
  1. [itex]M \vert \Phi_m \rangle = m \vert \Phi_m \rangle[/itex]
  2. [itex]\langle \Phi_m \vert \Phi_m \rangle = 1[/itex]
  3. [itex]\langle \Phi_m' \vert \Phi_m \rangle = 0[/itex], if [itex]m' \neq m[/itex]
The idea behind a "projection operator" [itex]M_m[/itex] is this:
[itex]M_m \vert \Phi_m \rangle = \vert \Phi_m \rangle[/itex]
[itex]M_m \vert \Phi_m' \rangle = 0[/itex], if [itex]m' \neq m[/itex].
So [itex]M_m[/itex] filters out any eigenstates that do not have eigenvalue [itex]m[/itex].
If you have such a projection operator, then the action of [itex]M_m[/itex] on an arbitrary wave function [itex]\vert \Psi_i \rangle[/itex] can be computed this way:
  • Write [itex]\vert \Psi_i \rangle[/itex] as a superposition of eigenstates of [itex]M[/itex]:
    [itex]\vert \Psi_i \rangle = \sum_{m'} C_{m'} \vert \Phi_{m'} \rangle[/itex]
    where [itex]C_{m'}[/itex] is just a coefficient. Note that [itex]C_{m'}[/itex] is the amplitude for state [itex]\Psi_i[/itex] to have eigenvalue [itex]m[/itex]. The probability is the square: [itex]P(m'\vert i) = \vert C_{m'} \vert^2[/itex].
  • Now apply the projection operator [itex]M_m[/itex]:
    [itex]M_m \vert \Psi_i \rangle = \sum_m' C_m' M_m \vert \Phi_m' \rangle[/itex]
  • By the assumed properties of [itex]M_m[/itex], all the terms in the sum vanish except one, leaving:
    [itex]M_m \vert \Psi_i \rangle = C_m \vert \Phi_m \rangle[/itex]
  • Now form the quantity [itex]\vert M_m \vert \Psi_i \rangle \vert^2[/itex]:
    [itex]\vert M_m \vert \Psi_i \rangle \vert^2 = \langle \Psi_i M_m^\dagger M_m \vert \Psi_i \rangle = \langle \Phi_m C_m^* C_m \vert \Phi_m\rangle = \vert C_m \vert^2 = P(m \vert i)[/itex]
  • So we conclude: [itex]\langle \Psi_i M_m^\dagger M_m \vert \Psi_i \rangle = P(m \vert i)[/itex]
This is correct.
[tex]p(m|i) = <\Psi_i| M^{+}_m M_m |\Psi_i> = <\Psi_i| M_m |\Psi_i>[/tex].
I guess what you mean is that M is a projector on an eigenstate with eigenvalue m (w/o degeneration).
I would use the letter M for an observable associated with m with appropriate (non-degenerate) eigenstates
[tex]M |m\rangle| = m |m\rangle[/tex]
and I would use P to indicate that we have an projector. So we have a clear distinction between the observable M w.r.t. which we define the eigenvalues and eigenstates and the projectors which project an arbitrary state to an eigenstate.
That means
[tex]p(m|i) = | \langle m|\Psi_i\rangle|^2 = \langle\Psi_i|m\rangle\langle m|\Psi_i\rangle = \langle\Psi_i|P_m|\Psi_i\rangle = \langle\Psi_i|P_m^\dagger\,P_m|\Psi_i\rangle[/tex]
where I use
[tex]|m\rangle\langle m| = P_m[/tex]
[tex]P_m = P_m^2[/tex]
[tex]P_m = P_m^\dagger[/tex]
Stevendaryl and tom.stoer! Thank you very much for your replies. I think I got it finally, one question that directly follows: is it then right to say that:
[itex]<M> = \Sigma p(m|i)m[/itex]
and hence [itex]M = \Sigma P_m m[/itex]
Yes. For the observable M you can write
[tex]M = \sum_m m\,|m\rangle\langle m|= \sum_m m\,P_m[/tex]
Everything else follows from this spectral representation (where I have used the assumptions of discrete and non-degenerate eigenvalues)
Ah..perfect. So the loop is closed :). Thanks once again!
