ODE Problem with boundary conditions
2 replies · 2K views
Pyroadept
Solve:
y'' - λy = 0
where y(0)=y(1)=0, y=y(t)
Hi everyone,
This is part of a PDE question, I just need to solve this particular ODE. I know how to do it in the case for y'' + λy = 0, where you get the solution:
λ = (nπ)^2,
y = C.sin(nπt), C a constant
However, I don't know how to go about doing it for this case, other than getting the trivial zero solution of course. Am I correct in thinking I should rewrite it as:
y'' + (-λ)y = 0
and then solve as for the positive case?
I would be really grateful if you could please tell me if this is correct.
In other words, you are assuming [itex]\lambdas< 0[/itex], right? Okay, how about setting [itex]\lambda= -\alpha^2[/itex] where [itex]\alpha[/itex] is any non-zero real number?
What is the characteristic equation for [itex]y''+ \alpha^2y= 0[/itex]. What characteristic roots do you get and what is the general solution?
Hi,
Thanks for your reply! So then I would have:
Assume λ<0
Let λ = -a^2, for some real, non-zero number a
Then
y'' + (a^2)y = 0
y(t) = c1.sin(at) + c2.cos(at)
y(0)=0, therefore c2 = 0
y(1)=0, therefore c1 = 0 (trivial solution)
or sin(a) = 0
a = n∏
so then λ = -(n∏)^2
So then y(t) = c1.sin(n∏t)
Then one of the conditions I was given in the question was that
∫(y^2)dt = 2, with limits of integration 0 to 1
Integrating this out:
(c1)^2.∫[sin(n∏t)]^2.dt =2
so then (1/2)(c1)^2.∫(1-cos(n∏t))dt =2
which gives us:
(c1)^2 = 4
c1 = ±2
So then y(t) = c1.sin(n∏t), c1=±2
I don't like that I've ended up with two possible values for c1, but this solution makes sense to me. Please could you tell me if I am correct?
