Solving Limits with L'Hospital's Rule
  • Thread starter Thread starter Likith D
    Algebra Limits
The forum discussion focuses on evaluating the limit $$y=\lim_{x \rightarrow 0} {\frac {1} {x^2}-\frac{1}{tan^2(x)}}$$ using L'Hospital's Rule and Taylor series expansion. Participants clarify that direct subtraction of limits is invalid when limits approach infinity, emphasizing the need for proper manipulation of expressions. The correct limit is determined to be $$\frac{2}{3}$$ through simplification and series expansion, rather than relying solely on L'Hospital's Rule.
  • Understanding of limits in calculus, specifically limits approaching infinity.
  • Familiarity with L'Hospital's Rule for indeterminate forms.
  • Knowledge of Taylor series expansions for trigonometric functions.
  • Proficiency in LaTeX for mathematical notation.
  • Study the application of L'Hospital's Rule in various limit problems.
  • Learn how to derive Taylor series expansions for functions like $$\tan(x)$$ and $$\sin(x)$$.
  • Explore the concept of indeterminate forms and how to resolve them through algebraic manipulation.
  • Practice writing mathematical expressions in LaTeX for clarity and precision.
Students, educators, and professionals in mathematics or engineering who are working on calculus problems involving limits and require a deeper understanding of L'Hospital's Rule and Taylor series.
Likith D
Find y;
$$\lim_{x \rightarrow 0} {\frac{tan(x)}x}=1$$
$$\lim_{x \rightarrow 0} {\frac{sin(x)}x}=1$$
\begin{align}
y & = \lim_{x \rightarrow 0} {\frac {1} {x^2}-\frac{1}{tan^2(x)}}\\
& = \lim_{x \rightarrow 0} {\frac {1} {x^2}}-\lim_{x \rightarrow 0}{\frac{1}{tan^2(x)}}\\
& = \lim_{x \rightarrow 0} {\frac {1} {x^2}}-\lim_{x \rightarrow 0}{\frac{1}{x^2}}\\
& = 0\\
\end{align}
or
\begin{align}
y & = \lim_{x \rightarrow 0} {\frac {1} {x^2}-cot^2(x)}\\
& = \lim_{x \rightarrow 0} {\frac {1} {x^2}+1-\frac {1} {sin^2(x)}}\\
& = \lim_{x \rightarrow 0} {\frac {1} {x^2}}-\lim_{x \rightarrow 0}{\frac{1}{sin^2(x)}+1}\\
& = \lim_{x \rightarrow 0} {\frac {1} {x^2}}-\lim_{x \rightarrow 0}{\frac{1}{x^2}+1}\\
& = 1\\
\end{align}
Plot on a graph, the solution seems to be $$\frac 2 3$$, which i do know how to come to using simplification and L'Hospital rule
But, I would like to know where I went wrong with my steps above
First of all: You are missing several parentheses that you really should have included.
It is not true that ##\lim_{x\to 0}[f(x) - g(x)] = \lim_{x\to 0}f(x) - \lim_{x\to 0}g(x)##. This is only true when all of these limits are well defined, which is not the case for the limits of 1/x^2 and 1/tan(x)^2. You need to actually manipulate the expression inside the parenthesis to produce an expression that converges properly.
In the step from 1 to 2
and from 6 to 7
You can't write something like ##\infty - \infty = 0 ##
But, it all happens such that the sum rule for derivatives of that function is true
...even when limits don't satisfy a sum rule?
The sum rule for derivatives is only true when the derivative's involved exist. Don't neglect the words involved in the rules for derivatives. The rules are not merely equations.
For example, let ##f(x) = |x|## , ##g(x) = -|x|## and ##h(x) = f(x) +g(x)##. The derivative of ##h(x)## exists at ##x = 0##, but the derivatives of ##f(x)## and ##g(x)## do not.
Likith D said:
Find y;
\begin{align}
& = 0\\
\end{align}
or
\begin{align}
& = 1\\
\end{align}
You seem to have had some vague idea of something that might work,But what you write is not very logical. Your (2) just repeats (1). Then you're taking to the limits looks based upon something that works for the reciprocals of those quantities. The ones of the problem are Infinite and, as has been said, the difference between two infinite quantities might be zero, finite or infinite.
Questions about limits are among the most common, possibly the most common, ones here. This one is more difficult than average.That suggests you have had problems or been given examples before, that would be helpful for you to look back on.
Otherwise it looks to me you are going to have to subtract an algebraic function from a trigonmetrical one. Then thinking logically you might think there is no way to do that, except if you can make the trigonometric one look like an algebraic one, i.e. expand It as a McLaurin series. This is not very easy for this function, but hopefully you only need a couple of terms, though you will need also to justify that.
Likith D said:
Find y;
You mean ##y = \lim_{x \rightarrow 0} \{ \frac{1}{x^2} - \frac{1}{tan^2(x)}\}## In latex brackets"{" don't show up as brackets. If you want to print a bracket, put a backslash in front of it like "\{".
##\lim_{x \rightarrow 0} \{ \frac{1}{x^2} - \frac{1}{tan^2(x)}\} = \lim_{x \rightarrow 0} \{ \frac{1}{x^2} - \frac{\cos^2(x)}{sin^2(x)}\}##
## = \lim_{x \rightarrow 0} \frac{sin^2(x) - x^2 cos^2(x)}{x^2 sin^2(x)}##
I haven't worked this myself, but you might make progress by applying l'hospital's rule several times. Eventually you will get terms with no ##x## in them.
I don't think it is necessary to use l'Hopital. I think the fastest way is to expand tan(x) keeping more than the leading term.
I think you are talking about taylor expansion of tan(x) term, but I'm unable to get simplifications for taylor expansion of tan(x) raised to power of -2. So, I'm not able to proceed further. Did you mean the taylor expansion of $$\frac 1 {tan^2(x)}$$?
Start by expanding ##\tan(x)## to order ##x^3##.
oh, yeah, I got it, thanks!
Do you mean that you got that particular part or that you managed to get the correct limit? It is difficult to tell if you don't write it out explicitly.
Well, yes, I did simplify the equation to get the answer as 2/3
And yes I find this method much easier compared to l'hospital's rule and repeated simplification , thanks for letting me know!
Key to your success was doing the check that showed that your first answer must be wrong.
:angel:
Don’t get too attached, in order to do the Taylor expansions you actually have to do the derivatives so it is effectively very similar to using l’Hopital ... It is just much easier to do it this way if you already are familiar with the expansions of some common functions.
Likith D said:
Find y;
\begin{align}
& = 0\\
\end{align}
or
\begin{align}
& = 1\\
\end{align}
If you insist on using l'Hospital's rule, re-write the problem first:
$$\frac{1}{x^2} - \frac{1}{\tan^2(x)} = \frac{\sin^2(x) - x^2 \cos^2(x)}{ x^2 \sin^2(x) }$$
Now that is in a form allowing straightforward application of l'Hospital, but an even faster way would be to expand the numerator and denominator in powers of ##x## and keep the lowest-order terms.
BTW: try to avoid writing ##tan(x)##, ##sin(x), ## or ##cos(x)##, etc; to get proper LaTeX (the way it was designed to be used) write instead ##\tan(x)##, ##\sin(x), ## and ##\cos(x)##; which you do by typing \tan instead of tan, \sin and \cos instead of sin and cos.
