What could potentially explain the onset of the Pioneer Anomaly?
  • Context: Graduate
  • Thread starter Thread starter GravityBound
    Anomaly pioneer
The discussion centers on the potential causes of the Pioneer Anomaly, specifically examining the role of solar radiation effects as proposed by Turyshev et al. and the residuals reported by Anderson et al. Participants express skepticism regarding the adequacy of the thermal model in explaining the onset of the anomaly. They emphasize the need for a more comprehensive understanding of the mismodeled solar radiation effects, particularly their correlation with the inverse square of distance from the Sun. Key studies referenced include Anderson et al.'s original research and Turyshev et al.'s analysis of anisotropic thermal effects.
  • Understanding of the Pioneer Anomaly and its significance in astrophysics
  • Familiarity with solar radiation pressure and its mathematical modeling
  • Knowledge of thermal models in spacecraft dynamics
  • Ability to interpret scientific research papers, specifically in the context of gravitational physics
  • Review Anderson et al.'s original study on the Pioneer Anomaly: Pioneer 11's onset
  • Examine Turyshev et al.'s research on anisotropic thermal effects: Thermal effects analysis
  • Investigate the implications of solar radiation pressure on spacecraft trajectories
  • Explore historical discussions and threads on the Pioneer Anomaly within relevant forums
Astronomers, astrophysicists, and researchers interested in spacecraft dynamics and the underlying causes of the Pioneer Anomaly will benefit from this discussion.
GravityBound
With regard to solar radiation effects causing the onset of effect, have any here investigated whether this is consistent with the observed residuals? Because the power of solar radiation is proportional to inverse square of distance from the Sun, it seems plausible to me that the mis-modeled effect of which Turyshev,etal speak is an under-modeling of solar radiation effects that fit a function of inverse square of distance from Sun. Even so I find that the residuals of Anderson, etal do not differ from the thermal model of Turyshev,etal by a function well correlated to inverse square of distance. If sufficient mismodeling (prop to 1/AU^2) is employed the fit isn't good but the onset is indicated.
It's not the thermal model I am questioning but the explanation of the cause of onset. That "Figure 2" is suggestive of the possibility that solar radiation effect may be the cause or at least part of the cause of the onset of effect is a reasonable intuition as far as I am concerned. Even so, getting the numbers to work is problematic when mismodeled solar radiation effects are modeled to be proportional to 1/AU^2.
Astronomy news on Phys.org
You need to post a link to the paper/other publication, or whatever you are referring to.
Sure. I just figured that any who might respond would be familiar with the published research.
The original study (Anderson, etal) from which one may obtain the residuals of Pioneer 11's onset https://arxiv.org/abs/gr-qc/0104064v5
The study on anisotropic thermal effects (Turyshev, etal) from which one may obtain the proposed thermal effects. https://arxiv.org/abs/1204.2507v1.
Just to be clear. I am not wanting to expand a discussion of what, if anything, is amiss with the hypothesis here. I am seeking others who may have examined the hypothesis and wish to know if they are fully satisfied with the hypothesis as an "explanation" or "model" of onset.
@GravityBound -- Welcome to the PF. :smile:
Have you done a PF search on this subject yet? There have been several long threads over the years here. You can also find several of them listed in the "Similar Threads" links at the bottom of the page. :smile:
Thanks for the link.
I also heard that the Juno spacecraft was slightly adrift of where it should have been on it's second bypass of Earth.
The only idea that made sense to me is that is that it might have been slowed a bit by passing through a comet trail of gas or such,
Yes, I did. But there is little regarding the onset of effect mentioned in those threads. From my perspective I do think that the thermal model is the primary effect at larger distances from the Sun (ie Pioneer 10 residuals), Pioneer 11 data covers what Pioneer 10 did not and the difference between a thermal model and the observation of Anderson etal are poor fit to any reasonable solar model IMHO. So I think it is reasonable to question whether there are other effects at play. If one reads Turyshev, etal. they, in so many words, say that leading into and closely following the Saturn encounter, the residuals varied through a broad range of magnitudes and so questioned whether there is an "onset". The fluctuation exceeded the thermal effects more than 2 fold. Whatever the case, it is certainly true that these observations (which did not participate in their report) are not consistent with the solar radiation hypothesis of onset observations.
I'll glance back from time to time to see if this thread attracts any comments of interest to me.
Oh ... and thank you for the welcome!
  • · Replies 42 ·
  • · Replies 28 ·
