On uniform boundedness of the GD algorithm
  • Context: Graduate
  • Thread starter Thread starter Vulture1991
    Algorithm Uniform
2 replies · 2K views
Vulture1991
Consider a function ##f\in\mathcal{C}^2## with Lipschitz continuous gradient (with constant ##L##)- we also assume the function is lowerbounded and has at least one minimum. Let ##\{x^k\}_k## be the sequence generated by Gradient Descent algorithm with initial point $x^0$ and step-size ##0<\alpha<2/L##:
\begin{equation}
x^{k+1}=x^k-\alpha\nabla f (x^k).
\end{equation}
We know that the sequence will converge to a critical point.
Now consider the new function ##\tilde{f}(x)=f(x)+x'Ax## with some ##A\succeq\mathbf{0}##. Let ##\{\tilde{x}^k\}_k## be the sequence generated by Gradient Descent algorithm with **the same** initial point ##\tilde{x}^0=x^0## and step-size ##0<\alpha<2/L##:
\begin{equation}
\tilde{x}^{k+1}=\tilde{x}^k-\alpha\nabla \tilde{f} (\tilde{x}^k).
\end{equation}
**Can we prove that ##\mathrm{dist}\left(\{\tilde{x}^k\}_k,\{{x}^k\}_k\right)## is uniformly bounded, independent of $A$ and step-size $\alpha$?**
I tried to prove it by assuming existence of a compact sublevel set ##\mathcal{L}=\{x:f(x)\leq f(x^0)\}## and using the fact that Gradient Descent generates a decreasing sequence of objective values (implying that the sequence remains in the compact sublevel set). However I cannot prove existence of a set independent of both $A$ and $\alpha$.
Do you have a reference where people can look up the algorithm in order to understand your question?
What is ##A## here, a matrix?
