One-dimension collision question
  • Thread starter Thread starter physics_geek
    Collision
13 replies · 7K views
physics_geek
A tennis ball of mass 44.0 g is held just above a basketball of mass 594 g. With their centers vertically aligned, both are released from rest at the same moment, to fall through a distance of 1.08 m,
(a) Find the magnitude of the downward velocity with which the basketball reaches the ground. Assume an elastic collision with the ground instantaneously reverses the velocity of the basketball while the tennis ball is still moving down.
(b) Next, the two balls meet in an elastic collision. To what height does the tennis ball rebound?
p = mv
KE = .5mv^2
gravitational KE = mgy
so i know its an elastic equation, thus meaning energy is convserved. i know that means i'll have at least two equations to solve for.
I really don't have any idea of where to start..please help?
(a)Well if you have to find the magnitude of the downward velocity of the basketball, why don't you start by finding the v of the basketball just before it hits the ground and it is reversed?
As you said, its elastic so why don't you try using PE(i)+KE(i)=KE(f)+PE(i) to solve for the v of the basketball.
(b) once you know the speed of the basketball on the way up, you can then use momentum considerations to find the velocity of the tennis ball, which can then be used to determine how far up it goes. One thing though, it doesn't tell you exactly how far down the tennis ball falls (because it was still falling when the b-ball hit the ground), so it couldn't have went the whole distance of 1.08m... hmmmmm
o ok
sounds a little confusing..but i'll try it
for the PE are we talking about gravitational potential = mgy ??
Yes. It might be helpful to think that, as the basketball falls, its PE is being converted into KE - when it hits the bottom all of the PE it had at the top has been converted into KE. Start by writing "PE at the top = KE at the bottom", then fill in the details (which should leave just one unknown that you can solve for).
The question is a bit confusing. I'm picturing the tennis ball practically touching the basketball initially, so both balls actually fall the full 1.08 m. In the absence of the separation distance number, I would treat it as too small to matter - perhaps less than 1 mm.
ok so i got the velocity of the basketball as it falls
now i just need to know how to go about solving the second part
no idea
An elastic collision is defined as a collision where energy as well as momentum is conserved... energy isn't lost to heat or used to deform the objects. In these cases you generally will get two equations, with two unknowns (usually the speeds of the objects right after collision).
In this particular case, they tell you the collision is between the basketball (moving upwards) and the tennis ball (still moving down). If you can find the speed of the tennis ball right after the collision, you will be able to know what height it reaches later.
PS. you should do this experiment... it's fun. (You can also find videos online.)
thanks a lot
i understand what you are saying
i just have no idea how to set up the equation
physics_geek said:
thanks a lot
You said it yourself...
So if KE is conserved, then, using subscript A=baseball and B=basketball and subscript 1=initial and 2=final
[tex](mv^2_1)_A+(mv^2_1)_B=(mv^2_2)_A+(mv^2_2)_B[/tex]
You should be able to set up a very similar equation for Linear Momentum.
Casey
im sorry i still just don't understand
im trying to read my book and it doesn't explain well
I find that long line of symbols rather disheartening, too!
I like to start the solution in words and then fill in the details with symbols as needed.
How about this for a start:
kinetic energy before collision = kinetic energy after, momentum before = momentum after
Under energy, write a .5mv2 for each moving object, before and after. Maybe use a little m for the little ball and a big M for the big ball. Similarly, use the momentum formula for each moving ball, before and after. The velocities before and after will be different, so perhaps you need 4 symbols - or you could just rely on the words "before" and "after" in the line I wrote.
On the next line, substitute numbers for all the symbols you know, such as m and M and the velocities you found in the first parts. If you are lucky, there will only be one unknown in one or both of the equations, and you will be able to solve the equation to find it. More likely, you will be faced with two unknowns - the velocities of the balls after the collision. When you have two equations, you can use them together to get the two unknown answers. We call it "solving a system of equations" in Canada. No doubt you have learned several methods for doing this. Look them up if you don't remember.
Well, whether the equation is something that is pretty to look at is rather trivial :smile:
Why don't you be a little more specific? Which part do you not understand? Have you read your text or looked at your notes? We do not provide solutions here, but we can walk you through the problem.
So let's see what you have written so far so we can see where you are having trouble :smile:
well
i solved for the velocity of the basketball on its way down
so i put mgh + .5mv^2 = 0
which gave me 4.6 m/s
now i know that i have to get some other equation right?
my teacher isn't the best english speaker so I am trying to improvise here haha
so do i do some kind of momentum equation like mv1 + mv2 = something
i have no idea?
physics_geek said:
well
i have no idea?
Did you even look at post number 8?
yes i did
to me that doesn't mean anything. i feel so dumb
i guess i'll try asking one of my friends
thanks for the help..sorry to be an annoyance
