One-Dimensional Kinematics: Height vs Time
The discussion revolves around solving a one-dimensional kinematics problem involving height and time on the fictional planet Zoot. Participants clarify that the standard free-fall acceleration of 9.8 m/s^2 does not apply in this scenario, prompting the need to determine the local acceleration due to gravity. To find this, the equation s = 1/2 at^2 + u*t can be used, particularly focusing on the second half of the graph where initial velocity is zero. Additionally, the final velocity can be calculated using u^2 = v^2 - 2*a*s, with the first half of the graph providing the necessary values. The exchange highlights the importance of context in physics problems and the collaborative nature of problem-solving.
rdn98
This problem has a picture. You can view it at http://www.geocities.com/rockdog_84/One.htm
Ok. Maybe I'm missing something here, but for part one, I thought free-fall acceleration would be 9.8 m/s^2. Of course, computer didn't take it, so is there a way to find it from the graph?
As for the second part of the question, I thought initial velocity is 0, but its not the right answer. :-(
I guess another way to find initial velocity would be take the derivative of x(t) when t = 0, but I don't know the equation for this problem.
Any insight is appreciated.
9.8 m/s^2 is the correct acceleration due to gravity on Earth, however the scenario in question takes place on the planet Zoot. If a question does not take place on Earth, then that is a big red flag that acceleration due to gravity is NOT 9.8 m/s^2.
You can figure out g by using s = 1/2 at^2 + u*t (Take the second half of the graph where u is 0).
Once you know g, you can use u^2 = v^2 - 2*a*s to find the final velocity. (Take the first half of the graph this time so v = 0)
Note: -
u = initial velocity
v = final velocity
t = time
a = acceleration
s = displacement
Claude.
big thanks!
Man, I would never have thought of that! Thank you so much.
  • · Replies 20 ·
