One last optimization problems
  • Thread starter Thread starter physicsed
    Optimization
The discussion focuses on solving an optimization problem to find two positive numbers that minimize the sum of a number and its reciprocal. Participants explore the derivative of the function x + (1/x) and discuss the application of the quotient rule in differentiation. There is some confusion regarding the calculations and simplifications of derivatives, particularly in handling terms correctly. The correct derivative leads to the conclusion that the minimum occurs at x = 1. The conversation highlights the importance of careful mathematical manipulation and clear communication in problem-solving.
physicsed
[SOLVED] one last optimization problems
find two positive numbers such that the sum of the number and its reciprocal is as small as possible.
x+(1/x) = s
f' =1 + ln x
lost
you've got it right so far. What happens to the derivative when something is at a minimum or a maximum?
1 + ln x =0
-1 = ln x
thats about all i can do
did you say there that
d/dx (1/x) = ln (x)?
physicsed ... you took the antiderivative ...
you have to take the derivative, not the integral
do u want me to use the quo rule for 1/x which is -1/x^2?
that is the correct answer, but you don't have to use the quotient rule to find it...
1/x = x^(-1) ... d/dx (1/x) = (-1)x^(-2) = -(1/x^2)
thats what i got to so far
(x^2 + 1)/ x
0=({{2x^2}-{x^2}+{1}})/{x^2}
which is undifined...
NO answer
(x^2 + 1)/ x
NO answer
You are missing ( ) in that. The derivative of (x2+ 1)/x, using the quotient rule, is
\frac{(x^2+ 1)&#039;(x)- (x^2+ 1)(x)&#039;}{x^2}= \frac{(2x)- (x^2+1)}{x^2}= \frac{x^2- 1}{x^2}= 0[/itex]<br /> when x= 1 or -1.<br /> <br /> Although it would be simpler, as others have pointed out, to write the function as x+ x<sup>-1</sup> so its derivative is 1- x<sup>-1</sup> which is 0 when x= 1 or -1.
whaaat
<br /> <br /> <br /> <br /> \frac{(2x)- (x^2+1)}{x^2}= \frac{x^2- 1}{x^2}<br /> <br /> how are those equal?
A slight mistake there (probably a typo), it should be:
\frac{(2x^2)- (x^2+1)}{x^2}= \frac{x^2- 1}{x^2}
(\frac{d}{dx}(x^2+1)) (x) = (2x)(x) = 2x^2
how are they equall?
As I said, HallsOfIvy made a little mistake (typo probably) in the calculation of the derivative.
He forgot to multiply the derivative of (x^2 + 1) with x.
so, i was right?
No.
You're answer was:
\frac{2x^2 - x^2 + 1}{x^2} = 0 which indeed does not have a solution.
The correct answer however should be:
\frac{2x^2 - (x^2 + 1)}{x^2} = 0 (there is one very important difference!)
<br /> \frac{2x^2- (x^2+ 1)}{x^2}= \frac{x^2-1}{x^2}<br />
(Is the forum messing up or are we just posting too fast?? :P)
\frac{2x^2 - (x^2 + 1)}{x^2} = \frac{2x^2 - x^2 - 1}{x^2} = \frac{x^2 - 1}{x^2}
\frac{x^2 - 1}{x^2} = 0 \ \rightarrow \ x^2 - 1 = 0 \ \rightarrow \ x = \pm \sqrt(1) = \pm 1
<br /> 2x^2 - x^2 - 1 = x^2 - 1<br />
it might sound childish, but how is that equal?
you can't factor anything or simplify it
Surely you can substract 1x^2 from 2x^2?
2x^2 - x^2 = (2-1)x^2 = 1x^2 = x^2. I can't write it out any more than that.
am soo stupid...thanks
No problem, it happens ;)
