One last optimization problems
  • Thread starter Thread starter physicsed
    Optimization
physicsed
[SOLVED] one last optimization problems
find two positive numbers such that the sum of the number and its reciprocal is as small as possible.
x+(1/x) = s
f' =1 + ln x
lost
you've got it right so far. What happens to the derivative when something is at a minimum or a maximum?
1 + ln x =0
-1 = ln x
thats about all i can do
did you say there that
d/dx (1/x) = ln (x)?
physicsed ... you took the antiderivative ...
you have to take the derivative, not the integral
do u want me to use the quo rule for 1/x which is -1/x^2?
that is the correct answer, but you don't have to use the quotient rule to find it...
1/x = x^(-1) ... d/dx (1/x) = (-1)x^(-2) = -(1/x^2)
thats what i got to so far
(x^2 + 1)/ x
0=({{2x^2}-{x^2}+{1}})/{x^2}
which is undifined...
NO answer
(x^2 + 1)/ x
NO answer
You are missing ( ) in that. The derivative of (x2+ 1)/x, using the quotient rule, is
\frac{(x^2+ 1)&#039;(x)- (x^2+ 1)(x)&#039;}{x^2}= \frac{(2x)- (x^2+1)}{x^2}= \frac{x^2- 1}{x^2}= 0[/itex]<br /> when x= 1 or -1.<br /> <br /> Although it would be simpler, as others have pointed out, to write the function as x+ x<sup>-1</sup> so its derivative is 1- x<sup>-1</sup> which is 0 when x= 1 or -1.
whaaat
<br /> <br /> <br /> <br /> \frac{(2x)- (x^2+1)}{x^2}= \frac{x^2- 1}{x^2}<br /> <br /> how are those equal?
A slight mistake there (probably a typo), it should be:
\frac{(2x^2)- (x^2+1)}{x^2}= \frac{x^2- 1}{x^2}
(\frac{d}{dx}(x^2+1)) (x) = (2x)(x) = 2x^2
how are they equall?
As I said, HallsOfIvy made a little mistake (typo probably) in the calculation of the derivative.
He forgot to multiply the derivative of (x^2 + 1) with x.
so, i was right?
No.
You're answer was:
\frac{2x^2 - x^2 + 1}{x^2} = 0 which indeed does not have a solution.
The correct answer however should be:
\frac{2x^2 - (x^2 + 1)}{x^2} = 0 (there is one very important difference!)
<br /> \frac{2x^2- (x^2+ 1)}{x^2}= \frac{x^2-1}{x^2}<br />
(Is the forum messing up or are we just posting too fast?? :P)
\frac{2x^2 - (x^2 + 1)}{x^2} = \frac{2x^2 - x^2 - 1}{x^2} = \frac{x^2 - 1}{x^2}
\frac{x^2 - 1}{x^2} = 0 \ \rightarrow \ x^2 - 1 = 0 \ \rightarrow \ x = \pm \sqrt(1) = \pm 1
<br /> 2x^2 - x^2 - 1 = x^2 - 1<br />
it might sound childish, but how is that equal?
you can't factor anything or simplify it
Surely you can substract 1x^2 from 2x^2?
2x^2 - x^2 = (2-1)x^2 = 1x^2 = x^2. I can't write it out any more than that.
am soo stupid...thanks
No problem, it happens ;)
