Open/closed air columns experiment
The forum discussion focuses on designing an experiment to determine the frequency of sound produced by open and closed air columns. The group initially used straws and a PVC pipe as reeds but struggled to achieve expected frequencies. They found better results with a recorder mouthpiece and plan to experiment with an empty wine bottle for closed air columns. Suggestions include using a bicycle pump to adjust the length of the column and tuning the pipe by immersing it in water to achieve resonance.
  • Understanding of sound wave frequency and wavelength relationships
  • Familiarity with open and closed air column acoustics
  • Basic knowledge of resonance and tuning techniques
  • Experience with experimental design in physics
  • Research the principles of resonance in open and closed air columns
  • Learn about tuning techniques using water immersion for sound pipes
  • Explore alternative sound sources for air column experiments
  • Investigate the use of a bicycle pump for adjusting air column length
Students in physics or acoustics, educators designing sound experiments, and hobbyists interested in sound wave manipulation and resonance techniques.
tete02
my group was designing an experiment for class where we have to find a length of a column, we started with open, to match a frequency we wanted. we started out with straws, and extended straws, to using the straw as a reed and blowing into a pvc pipe. nothing has worked, our frequency arent what we expect when we use the v=(wavelength)(frequency). we assume that our reed isn't effective, we even tried a recorder mouthpiece, but even the slightest blowing change will mess up the whole frequency. we did get better results with the mouthpiece than the straw. so, is there any suggestions for a reed or a better experiment. we are getting desperate and tomorrow we are going to try an empty wine bottle and do measurements for a closed air column and blow air across instead and hope we get the results we want. we did try playing around with a long closed glass tube and putting a funnel on the open part and blowing across but we were getting high frequencies even though the glass was pretty long. any suggestions to get more accurate frequency readings would be very helpful. thanks
If you hold your ear up against an open pipe in a noisy environment the pipe will "pick" its natural frequency out from among the noise. By holding your ear up against it it changes to a closed pipe though!
http://en.wikipedia.org/wiki/Pan_pipes"
You can "tune" the length of a pipe by immersing its open bottom end in a container of water. By raising or lowering the pipe in the water its inner length can be adjusted until you obtain the required frequency.
our teacher did the pipe in the water and adjusted it how far he dipped it into get the loudest resonance with a tunning fork. I just didn't want to copy that too much
What may you use as the source of sound? Just blowing over it is rather tricky. Did you look at the link in my previous post?
You can use a bicycle pump to adjust the length of the column (remove the front end).
9K
  • · Replies 17 ·
18K
