Open Source: Electrostatic Perimeter for Wildfire Mitigation
4 replies · 1K views
Hugox
TL;DR
Can we fight fire with physics?
This open-source concept uses high-voltage Pulsed DC (60kV-90kV) to electrostatically charge and deflect wildfire embers onto a safe zone, preventing fire spread.
Author: Hugo (16 years old)
Date: July 2026
Category: Applied Electrodynamics / Fire Protection Engineering
Licence: Open Source Hardware / Public Domain Concept
Author's Note:
I am 16 years old and I developed this conceptual idea to help mitigate the devastating effects of wildfires. Since I am still learning how to properly draft formal engineering documents and technical blueprints, I have used an AI assistant to refine my original thoughts, fix formatting, and structure this proposal into professional scientific language. My main goal is to share this open-source concept to see if it is physically viable for building a small-scale testing prototype. I look forward to your technical feedback!
Abstract​
Current perimeter protection methods against wildfires rely heavily on water resources or phosphate-based chemical retardants, whose logistics often fail during massive emergency situations. The Dynamic Electrostatic Perimeter System (DEPS) proposes a non-chemical physical alternative.It utilizes a combination of corona effect ionization, high-voltage pulsed wave modulation, and high thermal resistance materials to promote the electrostatic charging of carbonaceous particulate matter (smoke and embers), with the objective of increasing their probability of controlled deposition within a confined sacrificial zone.
1. Physical Foundations of the System
A flame is not simply a high-temperature gas; under combustion conditions it contains ionized species and free charge carriers, exhibiting limited plasma-like electrical behavior. The combustion front contains a significant volume density of positive ions (mainly ionized hydrocarbons such as $C_3H_3^+$) and free electrons.
By subjecting this flow to a high-intensity directional electric field, charge separation and electrohydrodynamic effects may be induced, potentially modifying the transport of charged combustion products and suspended particles. DEPS exploits this phenomenon and combines it with the principle of industrial electrostatic precipitators to act on the second major hazard of wildfires: embers (incandescent particles transported by the wind).
2. Structural Architecture and Materials​
The system consists of a linear and open geometry, optimized for deployment on the outer perimeter of residential zones or critical infrastructure.
[ Wildfire Wind ===> ]
(+) Emitting Line (Nichrome) [Pulsed High Voltage]
/ <--- Ionizing Electric Field (E)
(-) Collecting Line (Ground)/
[ Silica Insulating Blanket ]
[ //////////////////// Sacrificial Gravel / Mineral Soil ////////////////////// ]
2.1. Geometric Configuration (The Ramp)​
The system is not arranged vertically, but in an inclined ramp-like structure with an angle relative to the ground between 30° and 45°, facing the advancing fire front.
2.2. Materials Selection​
  • Conductive Element (Nichrome Mesh): A woven industrial mesh of Nichrome (80% Nickel, 20% Chromium) is used. This alloy is ideal due to its high commercial abundance and low relative cost compared to exotic metals. It features a melting temperature exceeding 1150 °C - 1200 °C, resisting direct thermal radiation from the fire front without losing structural integrity, and possesses excellent oxidation resistance at high temperatures.
  • Insulating Basal Layer (Silica Buffer Fabric): Directly beneath the metal ramp and in contact with the natural ground, a continuous blanket of high-purity silica fiber (or aluminized fiberglass) is deployed. This material acts as an absolute electrical insulator with high dielectric strength, continuously withstanding temperatures up to 1000 °C. Its function is critical: it encapsulates the energy within the Nichrome mesh and completely prevents current leakage into the earth, roots, or damp rocks.
  • Insulated Supports: The structure is maintained by steel posts electrically isolated from the mesh using alumina disc insulators (high-voltage ceramic insulators).
3. Electromechanical Dynamics and Ionization​
3.1. Electric Field Equation​
To induce a chronic ionic wind and sufficient attractive force on particles at metric distances, the system operates in the high-voltage range. The electric field $E$ generated near the conductive filaments of the mesh (assimilable to small-radius cylinders $r_w$) is governed by Gauss's law:
$$E(r) = \frac{V}{r \cdot \ln(R_c / r_w)}$$
Where:
  • $V$ = Applied potential difference (V).
  • $r$ = Radial distance from the conductor (m).
  • $r_w$ = Radius of the mesh filament (m).
  • $R_c$ = Effective confinement distance to the ground plane (m).
3.2. Ember Charging Mechanism (Pauthenier Effect)​
When embers and particles suspended in the smoke cross the ionic flow of the ramp, they undergo ion bombardment charging. The saturation or limit charge ($q_p$) acquired by a spheroidal ember is given by the Pauthenier equation:
$$q_p = 4\pi \cdot \varepsilon_0 \cdot \left(1 + 2\frac{\varepsilon_r - 1}{\varepsilon_r + 2}\right) \cdot r_p^2 \cdot E$$
Where:
  • $\varepsilon_0$ = Vacuum permittivity.
  • $\varepsilon_r$ = Relative permittivity of the carbon/wood particle.
  • $r_p$ = Average radius of the ember (m).
3.3. Migration Vector and Lorentz Force​
Once electrostatically charged, the particles are subjected to the Lorentz force within the field:
$$\vec{F}_e = q_p \cdot \vec{E}$$
This force acts perpendicular to the local electric field and may contribute to the deviation of the trajectories of charged embers from their purely aerodynamic paths.
The vertical migration velocity ($v_m$) towards the collection zone opposes the aerodynamic resistance of the hot air (Stokes' law with Cunningham correction $C_c$):
$$v_m = \frac{q_p \cdot E \cdot C_c}{6\pi \cdot \mu \cdot r_p}$$
Where $\mu$ represents the dynamic viscosity of the air. The proposed mechanism aims to increase the probability that charged embers deposit onto the non-combustible collection surface, where they may lose thermal energy and reduce their ignition potential. The actual collection efficiency requires experimental validation.
4. Power Management and Arc Flash Control (Pulsed Modulation)​
The greatest physical challenge of applying high voltage in the presence of wildfire smoke is the drastic reduction in the dielectric strength of the air. Hot smoke, saturated with conductive particles and ionized gases, facilitates the spontaneous transition from the corona effect to an arc flash (a continuous and destructive short circuit).
To solve this critical failure mode, DEPS implements a high-frequency Pulsed Direct Current (Pulsed DC) Power Supply.
  • Peak Voltage ($V_{peak}$): $60\text{ kV} - 90\text{ kV}$.
  • Switching Frequency ($f$): $1\text{ kHz} - 5\text{ kHz}$.
  • Duty Cycle: $5\% - 12\%$.
Rapid Switching Mechanism​
By applying the voltage in microsecond pulses, corona ionization and particle charging can be promoted while reducing the probability of sustained arc formation. The interruption of the voltage pulse limits the energy available for the development of a continuous conductive channel. During the off-time of the cycle, the channel naturally collapses.
5. Estimated Cost Analysis (Example per Linear Kilometer)​
To evaluate the market viability of DEPS against traditional defenses (such as concrete walls or water sprinkler systems), an estimated economic breakdown for the protection of 1 linear kilometer of the wildland-urban interface is presented:
Concept / ComponentTechnical DescriptionEstimated Cost (€)
Conductive Material (Mesh)Woven industrial Nichrome mesh (80/20), 2-meter width adapted to the ramp.€90,000
Basal InsulationContinuous high-purity silica fiber blanket (1000 °C thermal resistance).€25,000
Support InfrastructureGalvanized structural steel posts with alumina ceramic insulators for high voltage.€25,000
Power and Control SystemFast pulse modulation electronic unit ($90\text{ kV}$), transformers, and switching electronics.€110,000
Backup Power Unit$15\text{ kW}$ fossil fuel generator + ultracapacitor bank for peak discharge management.€40,000
Civil Works & InstallationGround preparation (initial clearing and placement of a sacrificial perimetric gravel strip).€35,000
Sensors & AutomationInterconnected optical and thermal PIR sensors for proximity activation by the flame front.€15,000
ESTIMATED TOTAL COST / KMInitial investment for a permanent active shield€340,000
Comparative Economic Viability​
Although the initial investment of ~€340,000/km exceeds the cost of traditional mechanical clearing with bulldozers, DEPS is highly competitive in the medium term due to three factors:
  1. Zero water consumption: It does not rely on tanks or a network of pipes prone to losing pressure or evaporating under extreme heat conditions.
  2. Operational lifecycle: The proposed materials (Nichrome, silica, and alumina) experience virtually no passive environmental degradation, minimizing annual maintenance costs compared to hydraulic systems.
  3. High-density invisible shield: It protects high-value assets (residential developments, industrial plants) with virtually zero landscape and ecological impact.
6. Safety and Automation​
To prevent indirect biological risks (wildlife, livestock, or firefighting personnel), the system integrates an automated control loop:
  1. Passive Infrared (PIR) and Optical Sensors: Monitor the perimeter line.
  2. Activation Logic: The system remains in a passive low-energy state. The high-voltage pulsed phase is only activated if the thermal and ionized signature typical of a flame front approaching within 50 meters is detected.
  3. Low Rms Current: By working with such reduced duty cycles, the average effective current remains in the milliampere ($\text{mA}$) range, ensuring that any accidental contact results in a non-lethal deterrent shock.
7. Conclusions and Future Research Lines​
The proposed model addresses the three major barriers of previous attempts at electrical manipulation of wildfires:
  • The short circuit caused by ground contact (solved by the basal silica blanket).
  • Component melting (solved by the thermal resistance of Nichrome).
  • The electric arc due to smoke (solved by fast pulse modulation).
This document is offered as an open-source theoretical foundation, inviting universities, thermodynamics laboratories, and electrical engineering departments to perform scale testing to calibrate the system's constants under real pyroconvection environments.
As an open-source conceptual proposal, DEPS should be regarded as a hypothesis-driven engineering concept requiring computational modelling, laboratory experimentation, and controlled field validation before any practical deployment can be considered.
I don't know if it will work, but I have personally seen a dry wooden pole catch fire solely due to the thermal radiation from a wildfire about 30 m away. Even if embers could be deflected, radiative heating might still remain a significant challenge.
Thank you for your valuable feedback, Roberto! You raise an excellent point regarding radiative heating. While the primary goal of the electrostatic field is to counter convective ember transport (spotting), radiant heat is indeed a massive challenge.
Instead of just relying on a cleared gravel zone, a technical solution to integrate into the DEPPS would be upgrading the lower grounded collecting line into a reflective metallic mesh screen. This would serve a dual purpose:
It increases the surface area for the grounded electrode, improving the collection of charged embers.
It acts as a physical Infrared (IR) shield. A fine, reflective mesh significantly reduces the thermal radiation "view factor," bouncing a large portion of the radiant heat back and protecting the unburnt zone behind it.
Additionally, the structural poles of the system could be treated with intumescent (fire-retardant) coatings to survive the intense heat. I really appreciate your input, it is exactly the kind of feedback I need to evolve this concept!
After a Mentor discussion, this thread will remain closed.
@Hugox -- Per the PF rules, we are not able to help with personal research here. We encourage you to keep pursuing your passions in STEM; that is a wonderful thing. But personal research is not allowed here.
Also, please keep in mind that AI-aided technical posts are not allowed here. They are problematical in their accuracy. Please do not use AI to aid your posts here in the technical forums. Please write them yourself.
But even more important, we want to make sure you are safe in this research work. Setting up flaming test setups can be very dangerous, so you should be sure to have local adult mentors who are advising you in this work and monitoring each of your experiments. I'm a Medic with some fire science experience, and it is too easy to underestimate your setup of the fireground. Please only proceed with this after you have qualified local mentors vetting your setups and your work. Thank you.
