Openning new files and write data into them
  • Thread starter vjramana
    Data files
vjramana
Hi,
I am trying to write a loop to open four main-data-files. At each open of main-data-file, I want the loop to open another four sub-files and split the data from mail-data-file according to the creteria and dump into the four files. And the process goes on. That means I will have total of 16 sub files for the four main-data-files.
I have tried to write the code as below but it doesn't seems to work.
program final
implicit none
integer :: i,j, k, m, jj, kk
integer, parameter :: dist_lines=256
real, DIMENSION(dist_lines) :: dist
! main-data-files
open(unit=100,status="old",file="selected_MAXdistance_only_malto_THERMO_1st.dat")
open(unit=101,status="old",file="selected_MAXdistance_only_malto_THERMO_2nd.dat")
open(unit=102,status="old",file="selected_MAXdistance_only_malto_THERMO_3rd.dat")
open(unit=103,status="old",file="selected_MAXdistance_only_malto_THERMO_4th.dat")
do kk = 100,103
! sub-files
open(unit=(10+kk), file="maximum_dist_001_064.dat")
open(unit=(11+kk), file="maximum_dist_065_128.dat")
open(unit=(12+kk), file="maximum_dist_129_192.dat")
open(unit=(13+kk), file="maximum_dist_193_256.dat")
read(kk,'(F8.3)') (dist(i), i = 1,dist_lines)
do k = 1, 256
if (k < 65 ) then
write ((kk+10),'(F8.3)'), dist(k)
elseif ( k >=65 .and. k < 129 ) then
write( (kk+11),'(F8.3)'), dist(k)
elseif ( k >=129 .and. k < 193 ) then
write ((kk+12),'(F8.3)'), dist(k)
elseif ( k >=193 .and. k < 257 ) then
write ((kk+13),'(F8.3)'), dist(k)
end if
end do
end do
stop
end
Could anyone help ?
Thanks in advance.
Vijay
When you say it doesn't work, can you be more specific?
Does it fail to compile?
If it compiles, does the program give incorrect results?
It compiles. There is no problem. But when I execute it stops says error. The error indicates that the files (maximum_dist_001_064.dat) open ready.
That means in the first call of the main-data-file ( UNIT=100) it opens four files. Thay are
When it calles the second file (UNIT=101), it tries to open another four files in the same name. So it stopes. I don't know how to make the four files to generate new names for each main-data-calling.
For example,
When it called file UNIT=100, the new four files might look like,
maximum_dist_001_064_100.dat
maximum_dist_065_128_100.dat
maximum_dist_129_192_100.dat
maximum_dist_193_256_100.dat
and when it called the second main-data-file, it might name as below
maximum_dist_001_064_101.dat
maximum_dist_065_128_101.dat
maximum_dist_129_192_101.dat
maximum_dist_193_256_101.dat
This allow me to know that the file generated are from calling UNIT=100, UNIT=101 and so on..
Hope this explain correctly how this code suppose to work.
Thanks in advance.
Right now you're opening the same files over and over. Plus, since you're not CLOSE() those files, you can't reopen the same file using the same unit number.
Code:
do kk = 100,103
! sub-files
That line will open up the file maximum_dist_001_064.dat everytime through the loop. If you want to open up a different filename each time through the loop, you can WRITE to a variable such as:
Code:
DO kk=100,103
WRITE(fname1,'(A21,I3.3,A4)') 'maximum_dist_001_064_',kk,'.dat'
OPEN(21,file=fname,form='formatted')
END DO
I'm not sure exactly what you're trying to do here, but it seems a little messed up in a few ways.
