Optical depth from radiative transfer equation
The discussion centers on deriving optical depth using the radiative transfer equation, specifically the equation $$\frac{I}{\tau}= I_0 e^{-\tau}$$. The proposed solution involves taking the natural logarithm of both sides to express optical depth as $$\tau= -\ln(\frac{I}{I_0})$$. The main concern raised is whether it is valid to exclude the source term S from the equation in this context. This indicates a need for clarity on the assumptions made when simplifying the equation.
  • Understanding of the radiative transfer equation
  • Familiarity with optical depth concepts
  • Knowledge of logarithmic functions and their properties
  • Basic principles of light interaction with matter
  • Study the complete form of the radiative transfer equation
  • Research the role of the source term S in radiative transfer
  • Explore applications of optical depth in astrophysics
  • Learn about numerical methods for solving radiative transfer problems
Students and researchers in physics, particularly those focused on astrophysics and atmospheric sciences, as well as professionals working with radiative transfer modeling.
Kayla Martin
Hi, I can't figure out how to find the optical depth for the following situation:
A supernova remnant has a brightness of I=1.5x10^{-19} Wm^{-2}Hz^{-1}sr^{-1} at frequencies around 1.6-1.7 GHz, but OH molecules in a homogenous foreground cloud produce an absorption line at 1667MHz. The observed intensity at the center of the line is 3.0x10^{-20} Wm^{-2}Hz^{-1}sr^{-1} and the width is 16kHz (corresponding to a velocity width of about 3km/s).
Assuming T_{ex}=12K throughout the cloud for this transition I need to use the radiative transfer equation to calculate the optical depth at the center of the line, tau_0.
Can someone please help me figure this out? I know we have been given all the equations for this in our lecture notes, but I am stumped at how to put it all together?
$$\frac{dI}{dS} = - \alpha I + j$$ where $$\alpha$$ is absorption coefficient...
$$\frac{dI}{\tau} = - I + S$$ where S is the source function $$S = \frac{j}{\alpha}$$ and $$\tau$$ is the optical depth.
The only solution (for part a) I can think of is if we use the radiative transfer equation without S... i.e. $$\frac{I}{\tau}= I_0 e^{-\tau}$$ and then take the natural log of each side to get $$\tau= -\ln(\frac{I}{I_0})$$ but I don't know if I can just get rid of S like that?
  • · Replies 19 ·
