Optical Fibres: Wavelength for Zero net Dispersion
3 replies · 2K views
Master1022
An optical fibre transmission system uses a step-index multimode optical fibre which has a core refractive index of 1.49 and a cladding refractive index of 1.48. The fibre is also subject to material dispersion which is a function of wavelength ## \lambda ##. The material dispersion coefficient D is given by:
[tex] D = a \lambda^2 + b\lambda + C \text{ps/km} [/tex]
where ## a = 0.01 ##, ##b = 0.50 ## and ## c = 50## and ## \lambda ## is the wavelength in nanometres. Estimate the wavelength at which the fibre has zero net dispersion.
D = 0
Hi,
I was working on the problem below:
Question:
[tex]D = a \lambda^2 + b\lambda + C \text{ps/km}[/tex]
where ## a = 0.01 ##, ##b = 0.50 ## and ## c = 50## and ##\lambda ## is the wavelength in nanometres. Estimate the wavelength at which the fibre has zero net dispersion.
Attempt:
Do we just let D = 0 and solve the quadratic equation? Is is that simple...
I was slightly confused as I know ## D = -\frac{\lambda}{c} \frac{d^2 n}{d \lambda^2} ## and perhaps there was a trick that we needed to use this.
Nonetheless, the first method yields the answers 4999 nm and 1 nm. Not sure how to choose between them, but I think the higher value might be correct as it is closer to the order of magnitude that we saw in a graph in the lectures (order of microns).
Any help or guidance would be appreciated
Charles Link said:
You need at least one of the coefficients of the dispersion function ## D ## to be negative if you are going to have a positive root ## \lambda ##.
Ah yes, you are right! Sorry, I think I forgot the -ve sign on ## b ##.
Reply
I think "c" also might need a minus sign, or you get imaginary roots. Please check your arithmetic=putting in minus signs on "b" and "c", I get roots of ## \lambda=+100 ## nm, and ## \lambda=-50 ## nm.
This one doesn't even need the quadratic formula=it factors: multiplying by 100 we get ## (\lambda-100) (\lambda+50)=0 ##.
