Optical path difference in a soap film interference
4 replies · 2K views · last reply
lorenz0
A soap water film ## n = 1.46 ## with a thickness of ## d = 10^{-6} m ## is placed on a glass plate with a refractive index of ## n = 1.6.## The film is perpendicularly illuminated by green light with a wavelength of ## 566 nm.## What is the optical path difference between the rays reflected from the two sides of the film, expressed in terms of the wavelength of the light inside the film?
##\Delta=\sum_i n_i d_i ##
The ray that is reflected at the air-soap interface has an optical path length of ##lambda_{soap}/2##, while the one refracted in the soap has an optical path length of ##2 n_{soap} d+\frac{lambda_{glass}}{2}## due to its traversing the soap film and also reflecting on the soap-glass interface. Thus the optical path difference between the two rays is ##\Delta=2 n_{soap} d+\frac{lambda_{glass}}{2}-\frac{lambda_{soap}}{2}## which can also be written as ##\Delta=\frac{2 n_{soap} d+\frac{lambda_{glass}}{2}-\frac{lambda_{soap}}{2}}{lambda_{soap}}lambda_{soap}\approx 7.49 lambda_{soap}##, which according to the stated solution is wrong, since it should be ##5.16 lambda_{soap}.## I would be grateful if someone could tell me where I am going wrong. Thanks.
There is phase change of 180° when the light reflects at the vacuum-soap interface and at the soap-glass interface so these cancel when you subtract. What's left?
That was my initial guess (that the phase shifts cancel out), and in that case it seems to me that ##\Delta=\frac{2n_{soap}d}{lambda_{soap}} lambda_{soap}=\frac{2 n^2_{soap}d}{lambda_0} lambda_{soap}##, so it still is not in agreement with the stated solution
That's because you counted the index of refraction of soap twice. The number of wavelengths you can fit in distance ##d## in vacuum is $$N=\frac{2d}{\lambda_{vac}}.$$ How many wavelengths can you fit in the same distance ##d## when the wavelength is ##\lambda_{vac}/n_{soap}##?
