Optical System: Two Identical Lenses w/2fo Focal Length
The discussion focuses on an optical system comprising two identical lenses, each with a positive focal length denoted as fo. It establishes that the focal lengths of the lens assembly, f and f', are equal for any separation distance d between the lenses. Additionally, it concludes that the separation required for the lens assembly to achieve a focal length of 2fo is d = (3/2)fo. Both the intuitive approach and the matrix method confirm this result, demonstrating the consistency of the calculations.
  • Understanding of thin lens equations
  • Familiarity with matrix methods in optics
  • Knowledge of focal lengths in optical systems
  • Ability to manipulate algebraic equations related to lenses
  • Study the derivation of the thin lens equation
  • Learn about matrix methods for analyzing optical systems
  • Explore the concept of compound lenses and their focal lengths
  • Investigate practical applications of lens assemblies in optical devices
Students and professionals in optics, physics educators, and anyone involved in designing or analyzing optical systems will benefit from this discussion.
zheng89120
An optical system consists of two identical lenses; the focal length of each lens is fo (where fo) is positive). The lenses are separted by a distance d. Denote the focal lenths of the lens assembly by f and f'.
a) Show that for any separation of the lenses f = f'
b) Find the separation between lenses that leads to the focal length of the lens assembly being equal to 2fo
thin lens equations, refracting/travelling matrices?, f' = -1/a21
a) I did the intuitive approach: a set of rays coming from either end of the 2 lense assembly will experience the same assembly, and hence converge to the same focal lengths (after exiting assembly at either end)
b) I used the matrix method with the matrix for thin lense being (1, 0; -1/fo, 1)
anyways, after some calculation... I got: d = (3/2)fo (correct?)
Not sure about the matrices but you could also use the formula for the focal length of compound lenses:
\frac{1}{f}=\frac{1}{f_1}+\frac{1}{f_2}-\frac{d}{f_1 f_2}
That will get you the same answer that you got for (b), so both methods get you the same answer. So I'd say (b) looks correct.
  • · Replies 0 ·
