Optimizing a BJT Amplifier Design for Specific Parameters
The discussion revolves around the design of a single-stage BJT amplifier with specific parameters, including input and output resistance, voltage gain, corner frequency, and the use of a specified transistor. Participants are exploring various calculations and configurations to achieve the desired performance, while also addressing issues related to component values and circuit behavior.
  • One participant outlines the design parameters and initial calculations for the amplifier, noting difficulties in achieving satisfactory results.
  • Another participant requests a schematic diagram to better understand the circuit layout and components used.
  • Clarifications are made regarding the components in the schematic, including the identification of an ammeter and voltmeter.
  • Concerns are raised about the mathematical laws being applied for component calculations, with some participants suggesting alternative approaches to achieve the desired voltage gain.
  • There is a discussion about whether the amplifier is intended to amplify frequencies below or above the corner frequency, with some participants suggesting a high-pass filter configuration.
  • One participant mentions the need for a Darlington configuration if a single transistor design proves inadequate for achieving the desired gain.
  • Another participant expresses skepticism about achieving a gain of 15 with a one-transistor design, citing issues with biasing and input sensitivity.
  • Participants discuss the impact of capacitor values on the output waveform and corner frequency, with some recalculating component values based on feedback received.
  • One participant reports achieving a gain close to 16 but notes distortion in the output waveform, indicating potential biasing issues.
Participants express differing views on the feasibility of achieving the specified gain with a one-transistor design, and there is no consensus on the best approach to resolve the issues encountered in the design process. Multiple competing views on component calculations and configurations remain present throughout the discussion.
Participants mention various assumptions and calculations that may not align, including the interpretation of input and output resistance, the role of capacitors, and the effects of component values on circuit performance. Some calculations are noted to vary as participants experiment with different values.
Individuals interested in BJT amplifier design, circuit analysis, and those seeking to understand the complexities of achieving specific electrical parameters in amplifier circuits may find this discussion beneficial.
Bourbon daddy
The outcome is: design a single stage amplifier with the following parameters:
Rin=1KOhms
Rout=1KOhms
Voltage Gain=15
corner frequency=300Hz
specified Transistor is BC109BP
AC supply, 0.5V
DC supply 20V
supply frequency, not specified, I have assumed 1K
We have not been given guidance on this, so I am muddling through a few blogs, particularly;
http://ampdesigns.tripod.com/engg_stuff.html
So far my results have been far from satisfactory in virtually every sense.
The circuit that I have based my own on can be found on this link:
(I can't seem to upload images of my own circuit, any pointers on this subject matter greatly appreciated).
A few of my calculations:
Icq=Icpeak+Icmin=0.03+0.005=0.035A
Selection of Re
Vre=10% VCC=2V
Re=Vre/Icq=2/0.035=57Ohms
RB is set at 1KOhm
R1 and R2
Vr2=Vbe+Vre=2+0.7=2.7V
Vr1=VCC-Vr2=17.3
R1/R2=Vr1/Vr2=6.407
Rb=1K
Rb=R1 in parallel with R2, keeping a 6.407 ratio between them
R1=8K
R2=1.24K
Rb=1.07KOhms
Xce=Re/10
c=1/2PI*(1k)(5.7)
=28uF
Xcc=Rc + Rload
c=1/2PI*(1k)(2K)
=80nF
Xcb=R1*R2/R1+R2...to note, I have used the frequency of 300Hz in this Calc as I believe . it sets the corner freq.
c=1/2PI*(300)(1K)
=530nF
I don't know what aspect of the design process is incorrect, but the output waveform seems to indicate that the capacitors are incorrectly sized to begin with, I am also not achieving a voltage gain of 15.
If anyone can point me in the right direction I will be very grateful.
Vin=0.6 Vout=3.863
Gain=approx. 6
If there is a way of uploading multisim files I will upload the circuit in its current form.
Here is a word document with some circuit images on.
https://www.physicsforums.com/attachments/68396
You need to show a diagram. Attach a permitted file such as .pdf, .doc or .jpg.
If your attachment was a WORD file then just change the name to xxxxx.doc.
What is U3? What is the thing connected between the base and emitter of Q1? The thing shunting R5? And what is th capacitor doing ending in mid-air next to R3?
Pretty hard-to-read schematic ...
View attachment Physics forum2.pdf
Apologies if it wasnt clear enough, U3 is an ammeter, thing connected between b and e was a voltmeter, same as R5... emitter cap was removed as I had removed it to check output signal waveform.
All peripheral equipment is now removed, so hopefully you will find it clearer.
What I seem to be struggling with is that I keep reading different mathematical laws to calculate the various components, none of them actually seem to work. In the last image, the component values are quite different, as I keep experimenting.
I have just read that G=(R2llRload)/r3
Hence the change to R3, (now set to 33.3Ohms)
I am getting closer to achieving a gain of 15, but the output waveform is heavily effected by the caps, and the corner frequency is someway off 300Hz.
Ooh, much better!
Ok now, to summarize:
Rin=1KOhms
Rout=1KOhms
Voltage Gain=15
corner frequency=300Hz : is this amp supposed to amplify frequencies below or above the corner frequency? Or do you want a passband around 300 Hz?
AC supply, 0.5V: what's this, the input voltage? there is no such thing as an ac power supply for this circuit.
DC supply 20V
Are you limited to a 1-transistor design? If not, look up what a Darlington configuration is.
According to my limited knowledge and my brief teachings, this is what I am working with;
Rin=1KOhms
For this, my belief is;
Rin=(R1llR4)llR3
I know that considering the values in the attached image my Rin would not equal 1K. I have been experimenting with different values and explanations of what Rin actually is. (Rin=R1llR3)
I seem to have this idea that I should be keeping a ratio of approx. 5.5 between R1 and R4. I can't remember why :/
Rout=1KOhms
Rout=R2
Voltage Gain=15
To set the voltage gain, first I tried;
G=R2/R3=1k/66.6
Then I tried;
G=(R2llRload)/R3=1k/33.3
My guess is either I am looking for a passband around 300Hz, either that or at 300Hz, dB should be approx -3dB.
Either way I am interested in frequencies above the 300Hz range.
To calculate this, I think I am interested in Cap in.
My understanding is the reactance of this component is equal to R1llR4, knowing that, we get
c=1/2pi*(300)(R1llR4)
If R1llR4 is equal to 1K
c=530nF
(again, different on the image due to me trying out different things)
I have probably been a bit amateur with my terminology, I know a transistor does not require an external power source.
0.5V is the input AC voltage, the peak of this, I assume is what I am amplifying. This voltage is generated by the function generator XFG1.
DC supply 20V
For the purpose of this task I am limited to this configuration, however I do need to analyse the Darlington pair for another task.
Finally, thank you for your time and responses so far, I do appreciate it. I am seeing my tutor at lunchtime today, so hopefully I can discuss my problems with him, but I would rather have better results than what I am already getting.
My opinion is that you will not be able to design a 1-transistor circuit of robust design (like being able to unplug the transistor & replace with one of same type) with a gain of 15V/V and an output impedance of 1K ohms. You do need a 33 ohm emitter resistor if you want a gain of 15 with a 1K load as you show. That significantly loads down the input bias pair R1 & R4 and it's beta-sensitive. That screws up your bias point. Quiz: what should the dc voltage at the emitter be? The input impedance is very beta-sensitive also. Transistor circuits should not be beta-sensitive.
Judging by your diagram you're looking for a high-pass amplifier (input frequency > 300 Hz). Your load coupling capacitor should be lower than what it is (why?). Your input capacitor should be large enough to pass > 300 Hz though it could be larger, depending on whether you want a 20 dB/decade or 40 dB/decade rolloff at 300 Hz.
Ok, first of all, I have basically started again, I have recalculated all component values (prior to going through your points) and what I get is;
a gain of approx. 16... currently I am happy with that, however, the output waveform is heavily distorted in the positive cycle, which suggests to me that the biasing is incorrect.
you are correct in assuming it is a high pass filter and because of his I have actually increased the cap in value, my calculations are as follows;
Cap in xc=R1llR4
c=1/(2pi(300)(1695K)
=313nF
The way I see it is, the role of this capacitor is to allow all frequencies above 300 to pass uninterrupted. All DC voltages will also be blocked.
Due to capacitors C1 and C2 I would expect to see no DC voltage at the emitter.
I am seeing a corner frequency of close to 300Hz, close enough for me to be happy.
My concern now is the heavily distorted output waveform, I need to go to class in a bit, but I will post pictures later on.
Cap in xc=R1llR4
=313nF
Correct. But C1 is a second high-pass filter. What value do you intend for it? And question: is it a good design if the cutoff frequency varies with the load resistance?
Alas, there you'd be wrong. What is the voltage at the base? What can you say about a transistor's Vbe unless it's totally shut off?
As I said, the design is not going to give you clean waveforms unless you start to think 2 transistors OR a higher output impedance OR a lower gain.
"Correct. But C1 is a second high-pass filter. What value do you intend for it? And question: is it a good design if the cutoff frequency varies with the load resistance?"
C1 in my understanding,
A) Blocks DC voltage
B) Sets the cut-off frequency
I have only concerned my self with the corner frequency, as set by C2. This Capacitor I have neglected.
to calculate the value of the capacitor,
C=1/2Pi(f)(R2llRload) with the frequency being 1KHz
You would require this capacitor to maintain its integrity over a range of load resistances I would imagine. Basic circuit theory tells me that if it wasnt you could be met with a scenario of cut off frequency increasing, reactance reducing, this could eventually result in an effective short across the cap, rendering it unsuitable.
"Alas, there you'd be wrong. What is the voltage at the base? What can you say about a transistor's Vbe unless it's totally shut off?"
Haha... Of course I am wrong... I am kicking myself over this, but its a new subject and I am still getting to grips with it.
Of course you would have DC voltage at the emitter, As for the Vbe, in operational mode, I have been taught that you would expect to see a value of 0.6/0.7V.
I think that Ve is approx. 10% of Vcc.
To calculate, you could work out;
Vcc-Vc-Vce=Ve
Voltage at the base can be calculated using
Vb=Vcc*(R2/R1+R2)
In my scenario I should be measuring 3V, but in reality I am actually getting roughly 0.3V
"As I said, the design is not going to give you clean waveforms unless you start to think 2 transistors OR a higher output impedance OR a lower gain."
After reworking my circuit I have managed to capture a good waveform that is showing heavy clipping on the negative cycle (phase shifted 180Deg so really I suppose it is the positive cycle).
It is a good clear image that will give me a lot to talk about in my assignment, and although I have not been able to successfully design an appropriate amp, I can evaluate and analyse my results and compare them with the theoretical results.
I am getting a gain of around 16, but obviously only on half of the waveform.
If your base voltage is only 0.3V then obviously the transistor is cut off fort small input voltages. Put in about 10 mV ac at say 1 KHz and see what you get at the output. the answer is zero!
I will drop this thread now but if you get a chance to go Darlington or some other set of specs we can talk again.
  • · Replies 25 ·
9K
