Optimizing parameter search with Newton's method and gradient descent
fahraynk
I have a system of equations which I solved with Newtons method.
Call Newtons method a function NM=f(K1,K2). K1 and K2 are input and a vector of x=x1,x2,x3,x4 is output.
I have another function, SSR, the sum of square residuals. It looks like this :
$$\sum (\frac{v_0-v_1X_1-v_3X_3-2v_3X_4}{H_t})^2$$
v1 and v2 are constants, v0 and H_t are experimental values which are known for several experiments. I sum over all the experiments.
Right now, I solve the system by Newtons method for a given k1 and k2. I then use a binary search or brute force to check every K1 and K2 over a range to find the minimum SSR.
The problem is it takes a long time, about 40 minutes per experiment and I have maybe 100 experiments to calculate. I would rather use something like gradient decent.
To do gradient decent I would need to take the derivative of the SSR function with respect to K1 and K2.
$$\frac{dSSR}{dK_1}=\frac{dSSR}{dX_1}\frac{dX_1}{dK_1}+ . . . \frac{dSSR}{dX_4}\frac{dX_4}{dK_1} \\\\ \frac{dX_n}{dK1}=\frac{dX_n}{dNM}\frac{dNM}{dK_1}$$$$
I can approximate the derivative of Newtons method with respect to K1 with NM(k1)-NM(K1+dK1)/dK1, but I have no idea if it is even possible to take the derivative of ##X_n## with respect to Newtons method!
Is it possible ? Or does anyone know a different way I can optimize this other than brute force and binary search?
Let's name the function and state it's arguments. Do you mean ##S(X1,X3,X4) = \sum_i (\frac{v_{0_i}-v_1X_1-v_3X_3-2v_3X_4}{H_{t_i}})^2## ?
It would be better say say that you solve the system "using " a given k1 and k2 for the values x1,x2,x3,x4, if that's what you mean.
It's best to state optimization problems in the standard form: That would be "Minimize ... with respect to choices of ... subject to the contraints:,,,,,".
In your case, the problem appears to be:
Minimize ##S(X1,X3,X4) = \sum_i (\frac{v_{0_i}-v_1X_1-v_3X_3-2v_3X_4}{H_{t_i}})^2##
with repect to choices of ##K_1,K_2##
##(X_1,X_2,X_3,X_4) = NM(K_1,K_2)##
where ##NM(K_1,K_2)## is the result of solving some system of equations by Newtons method for variables ##(X_1,X_2,X_3,X_4)##.
The correct notation would use partial derivatives - even though these are a pain-in-the-neck to write in LaTex.
##\frac{\partial S}{\partial K_1} = \frac{\partial S}{\partial X_1} \frac{\partial X_1}{\partial K_1} + ...##
The notation "##\frac{dX_n}{dK1}=\frac{dX_n}{dNM}\frac{dNM}{dK_1}##" makes no sense in the context of your problem.
The vector valued function ##NM(K1,K2)## can be represented as 4 component functions.
##X_1 = NM_1(K_1,K_2)##
##X_2 = NM_2(K_1,K_2)##
##X3 = NM_3(K_1,K_2)##
##X4 = NM_4(K_1,K_2)##
##\frac{\partial X_1}{\partial K_1} = \frac{\partial NM_1}{\partial K_1}##
Which step of the problem takes a long time? - using Newtons method? There are many tricks than can be used to speed up programs that solve particular sets of equations. For example, sometimes the final result of 2 steps of Newtons method can sometimes be implemented more concisely as a single sequence of code. Custom-made programs for solving particular sets of equations can be much faster than using a general-purpose equation solver.
There are quasi-random search methods, such as Simulated Annealing.
Thanks for your help!
Ah! I see that I made a big mistake. I think the partial of ssr should be
$$\frac{\partial{ssr}}{\partial{k_1}}=\frac{\partial{ssr}}{\partial{x_1}}\frac{\partial{x_1}}{\partial{k_1}}+ . . . \frac{\partial{ssr}}{\partial{x_4}}\frac{\partial{x_4}}{\partial{k_1}}$$
Originally I had the partial of ##x_1## with respect to NM, which was weird like you said.
Newtons method looks like this : $$x=x_{0}-G(H_t,G_t,k_1,k_2)*J(k_1,K_2)^-1$$
G is a vector consisting of 4 equations, and ##J^-1## is the inverse of the Jacobean matrix.
The output for a particular ##x_n## for ##n \in [1,4]## is a large equation, ##x_n=fn(x_1,x_2,x_3,x_4,k_1,k_2,H_t,G_t)##. I think I could either compute the derivative of this function, a giant mess, or I can approximate the derivative by taking the value of ##x_n## from Newtons method at two values for ##k_1## close together, and divide by ##dk_1##.
You asked "Which step of the problem takes a long time?"
Newtons method takes the longest, because for whatever initial guess I input, a certain percentage of the data does not converge. I ended up making a systematic method of guessing that does every possible combination of guesses, but it is a maximum of 100 guesses worse case for a choice of K1 and k2. Plus for every k1 I have to check a ton of K2 with this method, so it just takes a long time. I could try to develop better guesses, or lower the amount of guessed guesses to 50 or so, but I would rather just use gradient decent if possible because its a cooler algorithm.
