Understanding Orbital Angular Momentum Coupling to Christoffel Connection
The discussion centers on the coupling of orbital angular momentum to the Christoffel connection as described in Wen and Zee's article on topological quantum numbers in curved space. It is established that a spinning particle with orbital angular momentum \( s \) acquires an Aharonov-Bohm-like phase \( s \oint \omega \) due to the influence of the Christoffel connection \( \omega \). The Christoffel connection is crucial for defining the parallel transport of angular momentum vectors as particles move along geodesics. For accelerated motion, Fermi-Walker transport is the appropriate framework to consider.
  • Understanding of orbital angular momentum in quantum mechanics
  • Familiarity with Christoffel symbols and their role in differential geometry
  • Knowledge of Aharonov-Bohm effect in quantum physics
  • Concept of geodesics and parallel transport in curved spaces
  • Study the derivation of the Aharonov-Bohm phase in quantum mechanics
  • Research Fermi-Walker transport and its applications in general relativity
  • Explore the mathematical formulation of Christoffel connections in curved manifolds
  • Examine the implications of angular momentum coupling in quantum field theory
This discussion is beneficial for theoretical physicists, quantum mechanics researchers, and students studying general relativity and differential geometry, particularly those interested in the interplay between angular momentum and curvature in quantum systems.
psi*psi
I am trying to understand Wen and Zee's article on topological quantum numbers of Hall fluid on curved space: https://journals.aps.org/prl/abstract/10.1103/PhysRevLett.69.953
They passingly mentiond the fact that a spinning particle with orbital angular momentum $s$ moving on a manifold with Christoffel connection $\omega$ will acquire a Aharanov-Bohm like phase of $s \oint \omega$.
I can sort of see why the Christoffel connection will give rise to such a phase, since by analogy with the magnetic vector potential, the Christoffel connection will enter into the covariant derivative the same way as a magnetic vector potential. However, I do not understand why it would couple to the orbital angular momentum. I would really appreciate if someone could show me a derivation or point me to some references.
Thanks.
The Christoffel connection tells you which vectors in two nearby tangent spaces are "the same". A spinning particle is a gyroscope and wants to keep its angular momentum vector pointing in the same direction as it moves from point P to a nearby point. So the Christoffel connection is needed in order to define what that means.
For particles moving along geodesics, the motion is inertial, so one can just use parallel transport (i.e., the Christoffel term). For accelerated motion, there are fictitious forces, and the appropriate thing to use is called Fermi-Walker transport. I'm sure if you look that up, you can find a derivation.
  • · Replies 0 ·
