Orbital Nodes (Diagrams of Psi/Psi^2)
  • Thread starter Thread starter mistertaylor9
    Nodes Orbital
This discussion clarifies the representation of nodes in the wavefunctions of atomic orbitals, specifically the 2s and 5d orbitals. The 2s orbital graph intersects the x-axis at two points, indicating one spherical radial node. For the 5d orbital, the number of radial nodes is calculated as 2 (using the formula n-l-1), while the angular nodes are determined by l=2. The confusion arises from the misunderstanding that angular nodes are represented by x-intercepts; instead, they are scaling factors in the wavefunction decomposition, which is expressed as ψ(r,θ,φ) = R(r)Y(θ,φ).
  • Understanding of quantum mechanics and atomic orbitals
  • Familiarity with wavefunctions and their mathematical representation
  • Knowledge of radial and angular nodes in quantum chemistry
  • Basic grasp of spherical harmonics and their role in wavefunction analysis
  • Study the mathematical formulation of wavefunctions in quantum mechanics
  • Learn about the significance of radial and angular nodes in atomic orbitals
  • Explore the concept of spherical harmonics and their applications in quantum chemistry
  • Investigate graphical representations of wavefunctions for various atomic orbitals
Students and professionals in quantum chemistry, physicists, and educators seeking to deepen their understanding of atomic orbital behavior and wavefunction analysis.
mistertaylor9
I am having a hard time understanding the nodes on the graphs of Ψ for atomic orbitals. Take for example, the graph of Ψ for a 2s orbital as seen on the left here:
http://winter.group.shef.ac.uk/orbitron/AOs/2s/wave-fn.html
The graph intersects at two points, but these two intercepts represent the same spherical node.
Now consider the graph of Ψ for a 5d orbital.
http://winter.group.shef.ac.uk/orbitron/AOs/5d/wave-fn.htmlThe number of of radial nodes is 2 (from equation n-l-1) and the number of angular nodes is l=2. If one radial node causes the graph to cause the x-axis twice (on each side of nucleus, as in the case of the 2s orbital) then shouldn't there be 2 nodes * 2 intercepts/node = 4 intercepts just for the angular nodes? And then 2 more intercepts for the angular nodes? But the graph hits the x-axis at 5 (instead of 6) separate points which would imply 5 nodes but this isn't the case.
My only clue for the answer to my question is that maybe angular nodes are not represented by x-intercepts. Help meh!
What they're plotting on the (2D) graph in those figures is a cross section of the wavefunction. The cross section is taken along a radial line, i.e. a line that passes through the origin. So what you're seeing in the 2D graph is just the radial part of the wavefunction. The angular part is just a scaling factor.
In other words, you know that the wavefunction can be decomposed as
\psi(r,\theta,\phi) = R(r)Y(\theta,\phi)
where R and Y are the radial and angular parts, respectively. For a radial line, \theta and \phi are fixed, so Y(\theta,\phi) is just a constant for any given radial cross section. If you switch to a different radial cross section, though, it would have a different value. For example, in the 5d orbital you showed, the cross section was taken along the line x = y. If they had used x = 3y instead, the 2D graph would be smaller, but it would still have the same shape.
There are some particular angles at which the scaling factor Y(\theta,\phi) is zero; in this case, \phi = \{0,1,2,3\}\pi/2. If they had plotted a cross-section corresponding to one of those angles, the entire graph would be zero. Those angles are the angular nodes. You're correct that the angular nodes are not represented by x-intercepts.
By the way, since the cross sections they show in those graphs are taken along a full line, not a ray emanating from the origin, they actually show the radial wavefunction twice. So I'd actually suggest that you look only at the right half of the graph; the left half is just the mirror image. The center of the graph, of course, corresponds to the center of the atom, which is why a node at the center isn't part of a pair.
You have cleared a lot up for me. Thank you!
  • · Replies 21 ·
13K
