High School Calculating Orbital Radius for Hydrogen Atom with Given Angular Velocity
The discussion focuses on calculating the orbital radius of a hydrogen atom given an angular velocity of 1016 s-1. The user initially applies classical mechanics by equating centripetal and electrostatic forces, leading to the equation r3 = k * (e2) / (m * ω2). However, the response emphasizes that quantum mechanics governs electron behavior, and the calculated radius of 13.61 * 10-11 m does not correspond to the expected Bohr radius of 0.52 * 10-10 m. The discrepancy arises from the classical assumptions used in the calculation.
  • Understanding of classical mechanics principles, specifically centripetal and electrostatic forces.
  • Familiarity with quantum mechanics concepts, particularly the behavior of electrons in atoms.
  • Knowledge of the Bohr model of the hydrogen atom and its implications for electron orbits.
  • Basic proficiency in mathematical manipulation of physical equations.
  • Research the principles of quantum mechanics as they apply to atomic structure and electron behavior.
  • Study the derivation and implications of the Bohr model of the hydrogen atom.
  • Explore the differences between classical and quantum mechanical approaches to atomic physics.
  • Learn about the concept of probability distributions in quantum mechanics and how they relate to electron positions.
Students of physics, educators teaching atomic theory, and anyone interested in the transition from classical to quantum mechanics in atomic models.
psy
Hey guys,
The following thing got me a little bit messed up.
I want to calculate the orbital radii of an Hydrogen atom if the angular velocity of the electron is 10^16 * s^-1.
At first i set the centripetal force and the electrostatic force as equals.
( m * v^2 )/ r =k * (e^2) / r^2
v = ω * r
( m * ω^2 * r^2) / r = k * (e^2) / r^2
r ^3 = k * (e^2) / ( m * ω^2 )
r^3 = 8,99 * 10^9 Nm^2 / C * (1,60 * 10^-19 C )^2 / 9.11 10^-31 Kg * (10^16 s^-1 )^2
r^3 = (23,015 * 10^-29 Nm^2 C ) / 91,1 Kg/s^2
r =13,61 * 10^-11
While the Hydrogen radii is 0,52 * 10^-10 , I am checking it over and over again and can't find where i messed up.
Can someone tell me where i was wrong with the calculation?
Kind Regards
You are using classical mechanics, and the electron obeys the laws of quantum mechanics not classical mechanics.
In quantum mechanics the electron has no definite speed or position and does not follow a circular path around the nucleus the way the planets orbit the sun; instead we just have some probability of finding it in some spot near the nucleus if we look for it there. That ##5.2\times{10}^{-11}## radius is where that probability peaks.
(Googling for "hydrogen radius" will find many more links and the wikipedia article is not bad, but the math may quickly move past what belongs in a B-level thread).
Hi, I am coming to this cold but where does your initial figure for the angular velocity of the electron come from? This chosen value has to be right to get the right orbit radius.
Your starting equation looks ok (if k is given the right value) for a classical orbit. This Hyperphysics link starts in much the same way but the process is in terms of Energy. Start from a different direction, perhaps? (With QM in mind)
In the exercise I am doing its supposed that the electron moves in a circular orbit around the proton with the given velocity,
so I am tryng the classical mechanics with the centripetal and electrostatic force,where i can plug in the velocity of 10^16 s^-1 .
As the k I used 1/ 4*π*ε = 8,99 * 10^9 Nm/C^2 .
Why would you expect to get the value of the first Bohr radius? You get the radius corresponding to that velocity, in the classical mechanics framework.
It may be the right answer even it may irrelevant from the point of view of QM model. Even in the semi-classical Bohr model, there are more than one possible values for the radius of the orbit.
So don't worry. You got an answer but it's not surprising its the Bohr radius because it makes different assumptions.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
  • · Replies 20 ·
