Does light revolve around mass like the moon orbits the Earth?
  • Context: High School
  • Thread starter Thread starter TimeRip496
    Halo Light Mass
The discussion explores whether light can revolve around mass in a manner analogous to the moon's orbit around the Earth. Participants examine the implications of gravitational fields, spacetime curvature, and the behavior of light in strong gravitational environments, such as near black holes. The conversation includes theoretical considerations and thought experiments related to motion and gravity.
  • Some participants question whether light can revolve around mass like the moon orbits the Earth, suggesting that revolution may only be possible for objects with mass.
  • References to the concept of a photon sphere indicate that it applies specifically to massive objects, such as black holes, raising questions about its general applicability.
  • One participant proposes that the speed of an object affects its interaction with gravitational fields, noting that light, moving at high speeds, requires a strong gravitational field to maintain an orbit.
  • Another participant discusses the nature of gravity as curvature in spacetime, suggesting that all objects, including light, follow paths determined by this curvature, regardless of their speed.
  • A thought experiment involving a ball and a bullet illustrates how different speeds result in different paths through spacetime, leading to varying interactions with gravitational curvature.
  • Some participants clarify that while the ball and bullet may arrive at the same spatial location at different times, their trajectories and the concept of "same location" depend on the chosen reference frame.
Participants express differing views on the nature of light's interaction with mass and gravity, with no consensus reached regarding whether light can be said to revolve around mass in the same way as celestial bodies. The discussion remains unresolved, with multiple competing perspectives presented.
Participants highlight the complexity of gravitational interactions and the dependence on reference frames, suggesting that assumptions about motion and curvature may vary based on the context of the discussion.
TimeRip496
Does light moves (revolves) around around the mass like how moon orbits around the earth? Or revolution such as that of moon is only possible with something that has mass?
A.T. said:
When a meteorite fly pass a planet/star, is it possible for it to revolve around that planet/star in an orbit? If yes, does it applies for light? These questions I believe will better help me understand what curvature is. Photon sphere(me not very sure about it)seems to only applies for massive object like black hole, something which is not very general.
It's a specific application of a very general theory. The faster something is moving, the stronger the gravitational field needed to keep it in orbit. Light moves very quickly indeed, so it needs a very strong gravitational field to hold it in orbit. That means a massive object like a black hole.
But isn't gravitational field just bend in spacetime? And that a moving object will move along that spacetime regardless of its speed? Likewise light will move along that bend space time regardlessly. My apologies for such stupid question as I am still starting.
A very simple experiment will show you that the speed of the object makes a difference. Suppose you are standing at point A and you gently toss a ball at a target at point B; the ball follows a curved path to the target. Then you fire a bullet at the target; the bullet travels in a nearly straight line. So it seems clear that there is something different between the paths followed by the fast-moving bullet and the slow-moving ball.
What's going on here is that gravity is curvature in spacetime, not in just space. When you fire the bullet and throw the ball at the same time (that is, the bullet and the ball leave your hands at the same point in spacetime) the two arrive at the target at different times, and therefore different points in spacetime, even though the target is at the same point in space. Different paths means encountering different amount of curvature on the paths.
The faster a body is moving, the less time it spends in any given neighborhood, therefore it is less affected by the curvature.
Nugatory's post is very clear if you realize that the paths of freely falling bodies are "straight lines" (called geodesics) through the bent spacetime.
A circular orbit looks like a helix (spiral staircase) if you include the time dimension, and again, because of the curvature, that's "straight". Fast object = less time= more tightly wound spiral, so you need more curvature for that to be a geodesic.
Different speeds in space ->different directions in space-time -> different worldlines in space-time -> different trajectories in space
When you say the ball and bullet arrives at tge target at different points in spacetime, do you mean that they will arrive at the same location except at different point of time or both will end up at different location (e.g one end at on Mars while the other end up at uranus) as they will never end up in the same location regardless of time?
He wrote same location, different time.
But keep in mind that " same location" is only meaningful in some particular reference frame, say the Earth's. If the Earth is moving in your frame of reference the two points won't be at the same location. There may even be a frame that has the two collisions at the same time in different locations. "Different spacetime point", on the other hand, is an absolute term.
Edit: whoops- in this scenario the two events are "timelike separated"; you can get from one to the other at the speed of light or less. So no frame will have the events actually be at the same time. Delete that detail.
  • · Replies 53 ·
  • · Replies 22 ·
10K
  • · Replies 35 ·
  • · Replies 20 ·
  • · Replies 193 ·
16K
  • · Replies 58 ·
  • · Replies 29 ·
