General Relativity & The Sun: Does it Revolve Around Earth?
The discussion revolves around the implications of general relativity (GR) regarding the motion of celestial bodies, specifically questioning whether the Sun revolves around the Earth. Participants explore the validity of using Earth as a reference frame and the consequences of such a choice on the laws of physics, particularly in relation to the speed of light and inertial versus non-inertial frames.
  • Some participants argue that in general relativity, there are no privileged reference frames, allowing for the Earth to be considered as a valid reference frame for describing the motion of distant stars.
  • Others point out that if distant stars appear to orbit the Earth, this leads to coordinate velocities that could exceed the speed of light, raising questions about the validity of such a description.
  • It is noted that while coordinate velocities can exceed light speed, this does not violate the principles of relativity as long as the comparison is made with local light propagation.
  • Some participants discuss the implications of using non-inertial reference frames, suggesting that the laws of physics may not hold in the same way as they do in inertial frames.
  • There is a proposal that experimental results, such as those from a Foucault pendulum, can demonstrate whether the Earth is rotating in absolute terms.
  • Participants express uncertainty about how to definitively determine if one is in a rotating frame versus an inertial frame, noting that philosophical considerations play a role in interpreting these scenarios.
  • One participant mentions that an accelerometer can detect centripetal acceleration, but challenges arise in curved spacetime where distinguishing between different states of motion becomes complex.
Participants do not reach a consensus on the implications of using Earth as a reference frame or the nature of absolute rotation. Multiple competing views remain regarding the interpretation of motion and reference frames in general relativity.
Participants highlight limitations in defining absolute rotation and the complexities introduced by curved spacetime, indicating that the discussion is constrained by the assumptions made about reference frames and the nature of physical laws in those frames.
  • #181
PeterDonis said:
Still wrong. You have not grasped that the amount of "slowing down" you get due to the time dilation factor is less than the "slowing down" you actually see through your telescope, which is what "Doppler shift" means.
So, as I understand it, the whole phenomenon, as observed through the telescope, is called the Doppler shift. The reason for the Doppler shift is two contributing effects
1. varying light transit time
2. time dilation
You also continue to ignore the case where the spaceship moves towards you, and the Doppler effect you see through your telescope is a blueshift--speeding up, not slowing down.
True, but only a temporary ignoring while I try to get my head round the redshift.
  • #182
Yes.
2. time dilation
That's one way of looking at it, yes. The other way of looking at it is that Doppler shift is the fundamental thing (since that's what is actually observed), and "time dilation" is due to two contributing effects: Doppler shift and varying light travel time.
The first viewpoint (the one you described in the above quote) is going to seem more natural if you're used to thinking about SR in terms of inertial frames. The second (the one I described in the previous paragraph) is likely to seem more natural if you're used to thinking about SR in terms of spacetime geometry. I favor the second approach, but both are mathematically equivalent, so it's really a matter of personal preference.
  • #183
PeterDonis said:
Yes.
The reason why I wanted to mention the Doppler effect in my write-up when talking about Special Relativity is that when someone is learning SR it is tempting to think that the phenomena are just illusions and that behind it all there is something non-relative which is 'actually' happening. So I wanted to make clear that time dilation is a real thing and should not be confused with varying light transit time which is only responsible for an appearance of slowness - an optical illusion. I was inclined to call this varying light transit time effect the Doppler effect. Is it wrong to do that or is the word capable of being used in that restricted sense? If it is wrong, is there some other word which describes the varying light transit effect (isolated from the time dilation effect).
  • #184
And that is correct. The thing that is non-relative that is actually happening is spacetime and events in spacetime, such as you receiving light from some source with a particular redshift/blueshift at some event along your worldline. "Time dilation" is what might be termed an "illusion", since it's an artifact of your choice of coordinates (see below).
Relativity does not say "everything is relative". In fact Einstein at one point said the theory was misnamed, and should have been called the "theory of invariants"--the things that do not change when you change your choice of coordinates.
But here's the thing: time dilation is only a "real thing" if you say that things that depend on your choice of coordinates are "real things"; and doing that is problematic in relativity, since relativity says your choice of coordinates doesn't affect any physics. Whereas the actual observed redshift/blueshift in light coming from some other observer is a "real thing" in the simplest sense: it's what you directly observe.
  • #185
If we only do one experiment then I can see an argument could be made that the single observation of redshift/blueshift is all there is. But if we do many experiments we can show that redshift/blueshift is related to the speed at which the object is approaching/receding, in our direction (single dimension), and that there is a separate element - time dilation - which is related to the object's speed in 3D. So having done all the experiments with objects traveling at different angles and produced our mathematical theory which we believe models reality, is it not the case that we can then distinguish the time dilation element from the varying light transit time element?
  • #186
How do you measure the speed? You are aware that the standard way of doing this for distant objects is...using the Doppler shift?
In other words, this "speed" you talk about is not an independent variable in the usual case; it's just another way of describing the observed redshift/blueshift. To make it an independent variable, you would need to make other independent measurements of it, and that would require having a fleet of observers distant from you whose clocks were synchronized with yours and who were verified to be at rest relative to you, who could make local measurements of the object that is emitting the light you are receiving. In other words, to set up an actual concrete "inertial frame" centered on you.
If you do this, then yes, you can separate out "light travel time" from "time dilation", but now "time dilation" doesn't mean the same thing as it meant before. It now means, not a coordinate-dependent quantity that you calculate, but actual measurements that your fleet of observers is making, comparing their clock readings with those of the object emitting the light. Similarly, "light travel time" is now not something you calculate, but something your fleet of observers directly measures (by recording their clock readings as the light rays from the object pass them).
  • #187
PeterDonis said:
@JohnNemo the corrections you made look fine, but I did spot one other item:
"if a mass is accelerating that adds to the distortion"
What are you referring to here?
I was basing this on https://en.wikipedia.org/wiki/Frame-dragging but I am not sure about this. Is it just acceleration or any movement which adds to the distortion?
  • #188
Neither. Frame dragging, which can be thought of as an extra "distortion" to spacetime, yes, is due to the source of gravity having nonzero angular momentum, where "angular momentum" here is has a technical definition that is probably closest to "rotating with respect to the distant stars" of the concepts we've discussed--and where "rotating" here is to be taken in the intuitively obvious sense that someone "at rest" on the rotating object will see a given distant star as moving in a big circle around his sky instead of staying at a single fixed point in his sky.
This concept is different from any of the indicators of rotation we have discussed in this thread. For example, a black hole can be rotating in this sense, and a black hole is a vacuum solution, so there is no matter anywhere and therefore nothing that can have any proper acceleration or "motion" of any kind. It's all just spacetime geometry.
  • #189
https://en.wikipedia.org/wiki/Frame-dragging#Effects also mentions linear frame dragging. Is this also recognised n GR?
  • #190
I haven't seen anything about this in the GR textbooks and papers I've read. Unfortunately the Wikipedia article does not give a link to the Einstein lecture where he apparently mentioned it.
Offhand I would not expect an "similar" effect for linear momentum as opposed to angular momentum, for the same (heuristic) reasons as linear motion relative to the distant stars is not locally detectable the way that angular motion (rotation) relative to the distant stars is (putting aside all the subtleties we've been discussing about that). But it is true that for an object moving at high speed past a gravitating mass, GR makes different predictions than Newtonian gravity; it could be that this is what "linear frame dragging" is supposed to refer to.
  • #191
This is where I am having difficulty understanding because you often say (e.g. In #152) that a region of space a long way from the nearest star is flat (because the matter and energy in the universe is spherically symmetrical) but here we appear to have a distortion of spacetime caused by the distant stars moving in a big circle.
  • #192
Frame dragging only appears in the egregiously non-flat regions of spacetime near a massive rotating body; the distant stars are completely irrelevant to the spacetime curvature in such a region.
The only reason we mention the distant stars is that we said "near a massive rotating body" so we have be clear about what we mean by "rotating", and in this context an intuitive definition of "rotating" involves the distant stars.
  • #193
Is the bulge around the Earth’s equator caused by this type of frame dragging effect?
  • #194
No. That's a classical phenomenon, well understood since Newton.
Googling for "equatorial bulge cause" will find some good explanations.
  • · Replies 40 ·
  • · Replies 62 ·
  • · Replies 20 ·
  • · Replies 18 ·
  • · Replies 90 ·
  • · Replies 58 ·
