Ordinary Differential Equations by Tenenbaum and Pollard
The discussion focuses on the definition of a region in the context of Ordinary Differential Equations as outlined in Tenenbaum and Pollard's text. A region is defined by two conditions: each point must be the center of a circle entirely contained within the set, and any two points can be connected by a curve within the set. The first condition emphasizes that regions are open sets, as they do not include boundary points. An example provided is the set defined by 0 < x, y < 1, which illustrates the concept of open sets in R².
  • Understanding of open and closed sets in topology
  • Familiarity with the Cartesian coordinate system
  • Basic knowledge of curves and their properties
  • Concept of boundary points in mathematical analysis
  • Study the properties of open and closed sets in topology
  • Learn about the implications of boundary points in mathematical contexts
  • Explore examples of curves in R² and their characteristics
  • Investigate the applications of regions in Ordinary Differential Equations
Students and educators in mathematics, particularly those studying topology and differential equations, as well as anyone seeking to deepen their understanding of set theory and its applications in analysis.
Luterinho
I am having a hard time understanding the conditions that set a plane to be called a region.
According to definition 2.68, a set in the plane is called a region if it satisfies the following two conditions (p. 14):
1. "Each point of the set is the center of a circle whose entire interior consists of points of the set."
2. "Every two points of the set can be joined by a curve which consists entirely of points of the set."
I am having a hard time understanding the first condition. Can anyone provide an illustration in order to decipher the first condition meaning?
Thank you for help.
I think the counterpoint to 1 would be a boundary point. On the boundary, any circle you draw ( no matter how small ) will include some points from inside the domain and some outside.
Condition 1 indicates that the region is open. An example might be R2 with 0< x, y< 1. For any point near (0,0) or (1,1) there will exist a value r small enough that you can draw a circle around the point with only members of the region inside.
Thank you.
Yes. condition 1 is saying that the set does not contain any of its boundary points. The two sets \{ (x, y)| x^2+ y^2\le 1\} and \{ (x, y)| x^2+ y^2&lt; 1\} have the same boundary: \{(x, y)| x^2+ y^2= 1\}, the circle with radius 1. The first contains that boundary and is a "closed" set. The second does not contain any point of that boundary and is called an "open" set.
  • · Replies 65 ·
