Origin of Potential Energy - 65 Characters
The discussion centers on calculating the origin of potential for an infinite straight wire with a given linear charge density. Participants debate the formula for electric potential, V(r) = kq/r, and its implications regarding the chosen reference point for zero potential. While one participant suggests that the potential at infinity is zero, others clarify that this assumption may not hold true in all scenarios. The correct answer for the distance where potential is zero is identified as d) 30.2 m, emphasizing the need to derive potential from the electric field using integration. The conversation highlights the importance of understanding charge configurations and the relative nature of electric potential.
Guillem_dlc
If an infinite straight wire loaded with a linear density [itex]\lambda =10^{-8}\, \textrm{C/m}[/itex] creates a potential of [itex]239\, \textrm{V}[/itex] at a distance of [itex]8\, \textrm{m}[/itex] from the wire, calculate at what distance [itex]r_0[/itex] from the wire is the origin of potentials [itex] V(r=r_0)=0[/itex]. Express the result in [itex]\textrm{m}[/itex].
a) [itex]114[/itex]
b) [itex]10.6[/itex]
c) [itex]+\infty[/itex]
d) [itex]30.2[/itex]
[tex]V(r)=\dfrac{kq}{r}[/tex]
I think the right choice is c. I'll pass on my reasoning to you:
We can think that if the formula of the potential is
V(r)=\dfrac{kq}{r}
If r tends to infinity, then V(r)=0.
But the correct answer is d).
How did you derive (think ?!?) ##V(r)=\dfrac{kq}{r}## for this charge configuration ?
Guillem_dlc said:
Homework Statement:: If an infinite straight wire loaded with a linear density \lambda =10^{-8}\, \textrm{C/m} creates a potential of 239\, \textrm{V} at a distance of 8\, \textrm{m} from the wire, calculate at what distance r_0 from the wire is the origin of potentials V(r=r_0)=0. Express the result in \textrm{m}.
a) 114
b) 10.6
c) +\infty
d) 30.2
Relevant Equations:: V(r)=\dfrac{kq}{r}
V(r)=\dfrac{kq}{r}
Potentials are relative to some chosen zero. The formula V(r)=\dfrac{kq}{r} assumes the chosen zero is at infinity, but it need not be.
You are asked to find where the chosen zero is in this case.
V(r)=\dfrac{kq}{r}
Doesn' it worry you that ## q = \infty ##?
@BvU already addressed that aspect, but it seemed to me the OP also needed to be made aware that the potential at infinity need not be zero.
Perhaps I should have made that clearer.
Likes Adesh
Likes Delta2
It is a charged wire, not a point charge q.
The linear charge density is given, you have to use it instead of "q"
Likes Delta2 and Adesh
It’s misleading that the formula for potential is $$V = \frac{1}{4\pi \epsilon_0} \int \frac{\lambda (\vec{r’})}{\mathcal{r}} dl’$$ true. It is true but only when the charge density goes to zero at infinity. The above integration formula for potential is derived from the Poisson’s Eqaution $$ \nabla^2 V =-\frac{\lambda}{\epsilon_0}$$ (NOTE: I’m writing ##\lambda## instead of ##\rho## just to make this discussion more OP oriented). That Poisson’s Equation is a second order partial differential equation, which is very tough to solve, and for cases where the line charge density goes to zero we can solve it to get the formula in that integral form.
So, my suggestion is derive the formula for potential by integrating the electrical field along some path and between two points.
Likes Delta2
@Guillem_dlc : what do you know of the gauss theorem in connection with electric fields ?
  • · Replies 22 ·
  • · Replies 23 ·
