Why Is Answer A Correct for the Oscillation Problem?
  • Thread starter Thread starter magiclink
    Oscillation
The discussion revolves around a physics question regarding oscillation, specifically why answer A is correct. The participant initially believed that since the ball was described as "stationary," all forces must be equal, leading them to choose answer C. However, upon further reflection, they realized that the forces must sum to zero, indicating that the vectors indeed add up correctly to support answer A. The confusion stemmed from the interpretation of the question and the nature of vector addition. Ultimately, the participant acknowledged their misunderstanding and clarified that the question pertains to IB Physics.
magiclink
Hi! My question is about oscillation. The multiple choice answers and question is included in the picture attached! I also happen to know the answer is A by looking at the marscheme.
I would've thought that since the ball is said to be held "stationary" in that position the forces would all have to be equal. Thus i would've thought C was the correct answer. If they had said that it's an oscillation where the ball is in position P and not mentioned it being held stationary, I would've answered A, however, knowing that the forces would've had to be unbalanced and acting towards the equilbrium point. Could anybody explain exactly why it's A? and not C? I think my problem is probably largely due to interpretation of the question. Thankyou for any replies!
If the ball is stationary then the forces must sum to zero net force. If they were all equal, would the sum be zero? Remember, you're adding vectors here.
Hi, magiclink!
Is that IB Physics?
Hey! I just looked at the question and gave it a good look again. Turns out that the vectors did add vectorally to equal zero. A bit of an optical illusion to me. Thanks anyways! Sorry for wasting your time! :)
And yes, tis IB physics indeed. ;)
  • · Replies 18 ·
