greg997
- 105
- 2
Hi, I've got a few questions about that common base colpitts oscillator. I am trying to simulate it but, I am not sure if the circuit is complete or is it missing anything? I have some formulas but not sure how to use them.I have some assumptions, are they right?
1. Capacitors R3 R4 nad R5 can have any value, but at given frequency must act as short circuit, that means impedance must be small, so the capacitors value must be high. What is the resistance that is considerd short circuit? 1 Ohm? I can't see what I need that C4 for.
2. L resonant Q factor. From formula Q= wL/R. What exactly is that R? Is it like collector resistor in a dc circuit? And when I got Rload , how is it related to R? I've got something called [Total equivalent load resistance across oscillator output at given frequency. I ve got Rload, calculated from output power and peak Ac output.
I have formula Rt= (RdRo)/(RdRo), which does not make sense because the nominator and denominator are the same. Is the Rt= that total equivalent resistance?, then what is Rd and Ro? I've formula for Rd= L/Cr. but now i don't know what is Cr.
3. At what point should I see oscillation? Across the load or transistor? So far I can see only dc voltage equal input voltage. Should I seen pure sinewave?
Appreciate any help and explanation. Those values of resistors and capacitors are random. I just need general answer not calculations. Thanks
