Why does a paper roll unwind in jerks?
  • Context: Undergrad
  • Thread starter Thread starter ubergewehr273
    Mechanics Paper Roll
The discussion centers on the phenomenon of a paper roll unwinding in jerks rather than smoothly. The primary cause identified is the formation of creases during the rolling process, which store potential energy and release it in bursts when the friction from the creases is overcome. This results in a non-uniform unwinding motion characterized by nonlinear oscillations and dynamic instability. The paper roll is specifically noted to be placed vertically on a flat surface during the unwinding process.
  • Understanding of potential energy and friction dynamics
  • Familiarity with nonlinear oscillations and limit cycles
  • Basic knowledge of differential equations
  • Concepts of dynamic stability analysis
  • Research the principles of potential energy storage in mechanical systems
  • Study nonlinear dynamics and limit cycles in physical systems
  • Explore differential equations related to stability analysis
  • Investigate the effects of static friction on unwinding mechanisms
Physicists, mechanical engineers, and anyone interested in the dynamics of unwinding materials and stability analysis in mechanical systems.
ubergewehr273
TL;DR
Paper is rolled into a tube and it unwinds in jerks. Why is it so?
I came across a problem regarding a paper being rolled into a tube. When a piece of paper is rolled into a tube and then left to unwind, it is always seen that the unwinding happens in jerks and not smoothly. Why is it so?
What I have thought (and thanks to some discussions on reddit), that when one rolls a paper into a tube, creases form along the surface which in essence prevent the tube from unwinding smoothly. Potential energy gets stored and is released all at once when the force of friction due to the crease is overcome. This happens in intervals.
I would be glad if someone could correct me on this one and provide some further explanation on this phenomenon.
ubergewehr273 said:
.. then left to unwind,...
How exactly? Left in place, so the winding loosens up? Or rolled along the floor?
When it loosens in place, I suspect static friction is responsible for the non-uniform propagation.
Nonlinear oscillations are called limit cycles. They can be very difficult to analyze, but at the root there is some kind of dynamic instability.
Are you familiar with differential equations and stability analysis?
I'm sorry for not mentioning but the rolled paper tube is placed vertically on a flat surface and left to unwind.
I'm not familiar with the latter one.
OK
then read the second part of @A.T. 's answer :smile:
This could be quite complex. As the unwinding propagates around and into the roll, it could interfere with itself, creating phases of faster and slower movement.
  • · Replies 17 ·
13K
  • · Replies 19 ·
  • · Replies 52 ·
23K
13K
  • · Replies 62 ·
11K
  • · Replies 25 ·
