Papers on Splitting single particles
  • Context: Graduate
  • Thread starter Thread starter Quant
    Quantum field theory
The discussion revolves around recent articles suggesting that single particles may exhibit splitting behavior in double slit and Mach-Zehnder interferometer experiments. Participants explore whether this notion of splitting is compatible with quantum mechanics (QM) and quantum field theory (QFT), examining the implications of experimental results and interpretations of quantum phenomena.
  • Some participants express skepticism about the compatibility of the proposed splitting with QM/QFT, arguing that particles are fundamentally pointlike and not physically distributed.
  • Others suggest that the descriptions in the papers, such as "delocalization" of particles, are interpretation-dependent and do not necessarily imply a physical splitting of particles.
  • A participant notes that the experimental results are obtained through weak measurements, which may differ from traditional strong measurements, and questions the validity of the claims made in the papers.
  • Some argue that the papers do not present unexpected predictions of QM, as discussions about particle paths have been ongoing in the field.
  • There is a contention regarding the interpretation of the results, with some asserting that the authors do not strongly assume a specific interpretation, while others believe that certain descriptions imply a particular interpretation.
  • A participant emphasizes that particle detections are pointlike, and any claims about the physical distribution of particles require additional assumptions that are not justified.
Participants generally disagree on the interpretation of the experimental results and their implications for QM/QFT. There is no consensus on whether the notion of splitting is valid or how it should be understood within the framework of quantum theory.
The discussion highlights the complexity of interpreting experimental results in quantum mechanics, particularly regarding weak measurements and the implications for the nature of particles. Participants acknowledge that interpretations of quantum phenomena can vary significantly, leading to differing opinions on the validity of the claims made in the articles.
Quant
TL;DR
Experiments of 2023 show splitting of particles
Dear group members,
Can you express your opinion on the following recent (2023) articles insisting that single particles are split in parts in double slit and in Mach -Zehnder interferometer.Is this splitting compatible with QM/QFT? Parts of the abstracts are included here. The full articles are free accessible on Google Science.
A possible solution to the which-way problem of quantum interference Holger F. Hofmann
"Experimentally observable effects of small polarization rotations applied in the slits of a double slit experiment indicate that individual particles passing the slits before their detection in the interference pattern are physically delocalized with regard to their interactions with the local polarization rotations."
"Particles detected in the interference maxima experience no fluctuations at all, indicating a presence of exactly one half of the particle in each slit, while particles detected close to the minima experience polarization rotations much larger than the local rotations, indicating a negative presence in one of the slits and a presence of more than one in the other."
Quantifying the presence of a neutron in the paths of an interferometer Lemmel et.al.
"The results show that individual particles experience a specific fraction of the magnetic field applied in one of the paths, indicating that a fraction or even a multiple of the particle was present in the path before the interference of the two paths was registered."
@Quant, please give specific links when you reference papers; just saying "Google Science" is not enough. Here are the preprints I found on arxiv.org:
https://arxiv.org/abs/2111.03203v2
https://arxiv.org/abs/2202.00272
Are you asking whether the observed experimental results are "compatible with QM/QFT"? If so, the answer is yes, of course they are. Nor do the papers say otherwise.
If you are asking about the particular ordinary language description the papers use, such as phrases like "the particles forming the interference pattern must have been physically delocalized" or "an individual neutron moving through a two-path interferometer may actually be physically distributed between the two paths", those descriptions are interpretation dependent, so discussion of that would belong in the interpretations subforum (and there would be no way to actually resolve the question you are asking because interpretations are not experimentally testable, they all make the same predictions).
In QM/QFT a particle is pointlike (almost) not physically distributed.
Distributed is only the wavefunction and it has interpretations.
The fact that neutron is distributed in these experiments is experimental but results are received through weak measurements (introduced by Lev Vaidman) not usual strong ones.
My opinion is that neither QM no QFT predict something similar.
So this is a very initial incident where they fell and must be adjusted somehow as it happened with classical Electrodynamics after Planck black body formula or Newton mechanics after GTR.
The author don't claim this explicitly because of prudence. But clearly say the neutron were entered one at a time and this is not an average result by no means.
I hope other members will join the conversation.
  • Skeptical
My take is that you showed repeatedly that you don't have enough knowledge to have any opinion on that, and other matters of QM or QFT.
Nonsense.
Nonsense.
Summary: you are here not to learn, but to present some conspiracies and pseudoscience. What for? Like if real world and life wasn't tough enough.
After looking at the links provided by @PeterDonis, I guess I don't fully understand what you are trying to say. I don't read anything as an unexpected prediction of QM, nor as an unexpected experimental result. As indicated by references, there has been plenty of discussion in recent (and far past!) years about trying to nail down the path of quantum particles between times T1 and T2 when no direct observations occur. Generally speaking, there is no single (spacetime) path which can be assigned in all contexts.
So to me, when Hofmann refers to "delocalization", that seems normal - not new. And when you talk about a particle being physically split, that seems like description not justified from these papers. I certainly don't believe there is such a thing as two "half-electrons". But it would NOT be surprising (to me) to say a full electron is 50% here and the same full electron is 50% there - when we are not looking.
A lot of it goes back to interpretations (as mentioned by Peter), as different ones might describe these situations with different words.
It would be more accurate to say that particle detections are (almost) pointlike.
That is the only experimentally confirmed and interpretation-free fact that we have here. We can’t get from facts about particle detections to facts about particles without introducing usually unstated always unjustifiable additional assumptions about the behavior of unobserved particles.
I saw the author talk about this experiment on youtube and iirc they said it was just what they were expecting from quantum theory, nor do they strongly assume a specific interpretation I think. They must be just equating "particle" and quantum state / wavefunction in a super general way.
Also, re: what weak measurements and values show -
https://journals.aps.org/prresearch/abstract/10.1103/PhysRevResearch.5.023048
In terms of the results being consistent with what QM predicts, yes.
They don't explicitly do so, but as I noted in post #3, some of the descriptions given in the papers do implicitly assume a particular kind of interpretation.
That's the point in my argument. Broglie interpretation says neutron 100 % in one point/channel, Copenhagen -full electron 50% here and full electron 50% there, whenever these experiments point 1/2 neutron here and 2/3 there. Is this not totally different?
That's the point in my argument. Bohr interpretation is neutron is full and 50% in one channel 50% in other. De Broglie - neutron is full 100% in one channel, an empty wave travelling the other channel. Whereas the experiments show 1/3 in one channel and 2/3 in the other. Is this not totally different?
  • Skeptical
Moderator's note: Thread moved to the interpretations subforum.
  • · Replies 52 ·
  • · Replies 36 ·
9K
  • · Replies 24 ·
  • · Replies 91 ·
  • · Replies 19 ·
