ParaFOAM missing Qt platform plugin xcb on Mac
8 replies · 3K views · last reply
member 428835
Hi PF!
I'm using a mac and am running the CFD program openFOAM. As I'm going through a tutorial on openFOAM, I am instructed to type
Code:
paraFoam &
into the terminal. When I do so, I receive this error:
This application failed to start because it could not find or load the Qt platform plugin "xcb" in "". Reinstalling the application may fix this problem.
I googled this, and apparently there was the same issue here: https://www.cfd-online.com/Forums/o...942-openfoam-v1706-parafoam-failed-start.html
So I followed the final comment, where I was directed here: https://www.paraview.org/download/ and where I downloaded ParaView-5.5.1-1-Qt5-MPI-OSX10.8-64bit.dmg
But I still receive the same initial error. Any ideas?
Thanks!
jedishrfu said:
Did you click on the dmg file to install the plugin?
I'm confused what you mean by "the plugin" (sorry, I'm bad with computers).
From the first link I posted I assumed I did not have ParaView installed, so I thought I was using that .dmg file to install the program.
Yes that’s what I meant. When you said you downloaded it I thought you thought that as enough and that you didn’t use it to install something.
Having installed, paraview maybe you can try reinstalling the openFOAM software. Sometimes during an install, the software installer will detect its dependencies in this case paravie and configure them in.
To be clear, I do think it is sufficient to download the aforementioned .dmg at the link provided to have ParaView working on my machine (and consequently, the error I receive from the command line would not be there and instead ParaView would be opened). Am I wrong? Is there something more I need to install or have I installed ParaView incorrectly?
Install paraview and then install openFOAM. Beyond that I don’t know hat else to try. You could look for some openFOAM setup dialog or preferences dialog to see if there’s something there.
I think I've already installed both (I know I have OpenFOAM working since I can run the demos). Thanks, I'll poke around for more stuff. If you see anything please let me know!
On the off chance that this is helpful I’m posting it. There are other YouTube videos talking about installing openFOAM so if this doesn’t help then you might find one that will.
Google search is getting less and less helpful. There’s just too much similarly sounding words that confuse the search. Oh well.
