Parallel and perpendicular vectors
3 replies · 4K views · last reply
Gregg
If a mass takes a path down a slope of a parabola. The force downward is its weight. I need to resolve the perpendicular and parallel (to direction of motion) forces.
y=ax^2+bx+c, it has a y intercept of h and a repeated root l. a>0. The mass slides from x=0 to x=l with no friction.
[itex]d\vec{r} = \left(<br /> \begin{array}{c}<br /> 1 \\<br /> 2ax+b<br /> \end{array}<br /> \right)\text{dx}[/itex]
A unit vector in this direction:
[itex]\hat{u} = \frac{1}{\sqrt{1+(2ax+b)^2}}\left(<br /> \begin{array}{c}<br /> 1 \\<br /> 2ax+b<br /> \end{array}<br /> \right)[/itex]
To get the size of the component of the force parallel to the curve:
[itex]mg \cos (\theta) = mg\frac{(2ax+b)}{\sqrt{1+(2ax+b)^2}}[/itex]
[itex]mg \cos (\theta) \hat{u} = mg\frac{(2ax+b)}{\sqrt{1+(2ax+b)^2}} \frac{1}{\sqrt{1+(2ax+b)^2}}\left(<br /> \begin{array}{c}<br /> 1 \\<br /> 2ax+b<br /> \end{array}<br /> \right) = mg \frac{(2ax+b)}{1+(2ax+b)^2}\left(<br /> \begin{array}{c}<br /> 1 \\<br /> 2ax+b<br /> \end{array}<br /> \right)[/itex]
I don't think this is right
This can't be right because then
[itex]\int \vec{F}\cdot d\vec{r} = Mg(al^2 + bl) \ne Mgh[/itex]
There is a subtle mistake at play here. You want the magnitude of the parallel force component, i.e., its absolute value. So there should be a big absolute value sign on the r.h.s. in that last equation.
The absolute value is not an issue for m, g, and the square-root expression since those are all positive. But what about the 2ax+b term, is that negative or positive?
Hints:
1. We are only considering 0<x<l.
2. Express a and b each in terms of h and l, if you have not already done so.
test
