Parallel Capacitors: C1+C2 or C1-C2?
The equivalent capacitance for two capacitors in parallel is calculated using the formula Ceq = C1 + C2. In the discussed scenario, where the positive plate of one capacitor is connected to the negative plate of another, the configuration does not change the fundamental rule of parallel capacitance. The effective capacitance remains C1 + C2, as the connection method does not alter the total capacitance in parallel arrangements.
  • Understanding of basic capacitor theory
  • Familiarity with electrical circuit components
  • Knowledge of parallel circuit configurations
  • Basic principles of charge and voltage in capacitors
  • Study the effects of series vs. parallel capacitor configurations
  • Learn about the implications of capacitor connections on total capacitance
  • Explore practical applications of capacitors in electrical circuits
  • Investigate the behavior of capacitors under different charging conditions
Electrical engineers, electronics students, and hobbyists interested in understanding capacitor behavior in circuit design.
flyers
I know that the equivalent capacitance for two capacitors in parallel is C1+C2=Ceq. But consider I charge 2 plate capacitors so that each capacitor has a positive and negative plate and then I connect the positive plate of one cap. to the negative plate of the other capacitor in a parallel connection. My question is should the equivalent capacitance be c1+c2 OR c1-c2?
c1 + c2
It's like adding two containers of volumes v1 and v2. The net size of the resulting container does not depend upon the contents.
