Parallel keyboard with simultaneous key presses for faster typing
  • Thread starter Thread starter Bartholomew
    Keyboard Parallel
66 replies · 19K views
The keyboard would be significantly larger than usual.
Ye of little faith in the learning powers of the human mind... How did any of you ever learn to ride a bicycle? Ludicrous, that one could balance on two rolling wheels.
Oh ye of too much faith in non-existant technology. I will await your results with an apology ready to go when this comes to market.
Unfortunately I do not yet have the engineering capabilities to make this keyboard. Perhaps in three or four years. But the question is... why are you all so opposed to this possible new idea? Is it just because raising objections is easier than making suggestions?
That would be a downside. With technology moving toward smaller and more portable, anything that increases size is not going to be seen as an advantage.
Balance involves much simpler neurological processes than learning languages. The keyboard you describe would essentially require learning a new language to use it, because the way written language is currently processed by the brain would have to be dramatically changed to type all the letters in a word at once. Think of it like learning to play a piano. It's much simpler to learn to play one note at a time than it is to learn to play chords, and then to play chords with both hands. You can get reasonably proficient at typing or playing a piano one note at a time in a fairly short amount of time...a few weeks or months of practice. In the meantime, you can still use a keyboard without knowing how to touch type by using the hunt-and-peck method. On the other hand, building proficiency in playing chords on a piano can take years, and even then, most pianists need to spend a lot of time practicing individual pieces so that even with the notes in front of them, they can get all the chords right, because it's not that natural to think of all the letters or notes of a language simultaneously, but in series. Even then, when you're playing a piano, until you've truly mastered it after perhaps a decade or two of learning, you use a fairly limited number of chords (vocabulary) in music, they follow set rules based on keys. In writing, the letter combinations and vocabulary are much more extensive. It's also much harder to learn new languages once we start hitting even teenage years. You're asking a lot to expect adults to still have the adaptability to learn a new language so completely in order to use this new keyboard.
Because most of us think it's a bad idea, and you've been unreceptive to the suggestions made!
My mum hardly ever uses a computer, but she knows that when she does eventually want to type a letter, all the keys are there, and she can press them in the same order as she would use if writing the letter with a biro. And for most of us, input speed is not a critical factor. Whether I'm writing a 10,000 word report, or chatting on MSN, I can physically type far faster than I can process what I want to type. Having to know (subconsciously or otherwise) exactly which letters I need before I've started writing a word is completely out of the question.
By all means, gain the "engineering capabilities" you require to make this keyboard and prove us wrong, I'm a sucker for being proved wrong. But after all, you posted here to ask for popular opinion...
A system similar to the one suggested is used, but not to type fast. It is used by people like Hawking with ALS who have a very limited capacity to type. You type a first couple of letter and your are given a menu of words from which you can pick.
Fast typing systems with multiple keystrokes are called machine shorthand and there are numerous versions. One example is here: http://www.spellingsociety.org/journals/j16/palantype.html
They work mostly by converting several letters that create a single sound into one entry. Certain common words or phrases have their own keys. For example, court reporters typically set up a "hotkey" for a name used often in the material transcribed.
Thank you, ohwilleke, for your link to palantype. 180-200 wpm. on a system which is certainly not letter-by-letter, and which does include chording; and in operation is in fact rather similar to the method I proposed. I believe this squelches the objections of many people.
No, it's not letter by letter, but there are a number of important distinctions between what you proposed and what that palantype system uses. First of all, the palantype system does not expect you to spell out entire words at all, but uses phonemes. So, you are not trying to think through the spelling of an entire word at once and hitting all the letter keys at once, but translating syllables into characters representing the sounds in those syllables. You've also proposed a keyboard with repeated letters such that it would be larger than a standard QWERTY keyboard. The palantype keyboard is quite a bit smaller. The QWERTY keyboard (or any keyboard involving serial typing) can by used by anyone without any special training, although training and practice will allow you to become faster at typing. The palantype keyboard, or any stenograph machine, requires special training, again, because even if you have a software package to generate the output, the input still requires learning another language for typing. You aren't using all the letters or spelling in the traditional way when using that. Have you ever taken a course on steno or shorthand? Even after a full semester of learning steno in high school (in the hopes of speeding up my note taking), I was never very good at it, and I was one of the better students in the class! - it just wasn't worth the effort to bother continuing to work on after that considering I wasn't aspiring to a career as a secretary or court reporter. Comparatively speaking, touch typing was much easier to learn, even back when I was learning on an actual typewriter with keys that were hard to press (I remember how much my fingers used to hurt when I was learning to type...keyboarding is much easier).
If you didn't want honest feedback, why ask?
I did want honest feedback.
There are certainly some differences--the number of words needed to memorize is smaller on the palantype, and you would use more key presses to form most words on the palantype. But in general, the system is: you learn a new way of doing things, pressing multiple keys at once, in ways which are initially confusing. I don't think in terms of phonemes, either; it can be learned. As to the smaller keyboard... pfft, that is a difference so unimportant for the purposes this would be used...
But you do think in terms of phonemes. That's how you speak. So, if you don't want to listen to us and are sure we're all wrong and you're right, go ahead and make the thing. Put your money where your mouth is and settle it once and for all. If you are successful with it, I'll be glad to offer a public retraction and apologize for doubting your idea.
You should be making the retraction now because the machine has already been made. You can argue that we think in letters as much as you can argue that we think in phonemes; the truth is we do neither without training. We speak with sounds; we do not consciously break it into phonemes, much less key combinations that correspond to phonemes.
A phoneme IS a sound. http://cslu.cse.ogi.edu/tutordemos/SpectrogramReading/phoneme.html
And I did say that typing symbols to represent them is still going to require a lot of learning. It's not so easy as you're making it out to be. I suggest that before you embark on this, you study up on some linguistics. It will help you understand how people use language. If you're going to construct a keyboard that is easier to use than the current keyboard, then it's going to need to take into account how people utilize language. That keyboard that has already been made is NOT the same as what you've been describing, and we're discussing the limitations of your keyboard, not theirs. If you don't want to listen to critiques of the idea, don't bother asking us for comments.
So why the hell am I typing this on a qwerty keyboard then?!
Dead...horse...flogging...
If a human beings thought completely in pictures and had the ability to see a word in its entireity in their minds before typing it, not to mention the ability to recall almost instantaneously what the positions of all of the letters in that word were on the hypothetical parallel keyboard, thereby having their fingers in the position to plonk down on those keys (not to mention the dexterity and coordination to have each finger land on its designated key without any misses), all within a fraction of a second, THEN I would be quite enthused by this idea. However, as Moonbear has pointed out, people, in general, aren't capable of such a feat. IMO, it's much more efficient to decide what word you want to use and type the letters one by one. My 2 cents...
No, moonbear, a phoneme is a very particular type of sound, which in fact we do not consciously think or speak with. And I never said it would be easy; I said it would be fast and be for a specialized market of people who want to type fast. Why are you even raising that objection when you already know this?
The rest of you... I can hardly believe you people. Brewnog, you are not typing on a Palantype keyboard because you are not a court typist. Cepheid, Palantype proves it is more efficient to enter words in larger chunks, pressing multiple keys at once, than letter-by-letter.
That said, the original idea is a "parallel keyboard" where multiple pieces of data are entered at once for faster typing. They have been made. Wholesale criticism from all directions is not appropriate given this circumstance; things that may have been appropriate, for example, are "how about entering syllables instead of entire words, to speed learning of the system?" or... or... well, that's the only difference between my proposed system and palantype, so I guess for other suggestions you'd have had to be creative.
Phonemes are the sounds we use when we speak. The symbols and definitions linguists use to describe individual phonemes are complicated, but they are based on the sounds we make when we speak. Linguists study them because they are a part of how we use language. It doesn't matter if we consciously think about how we break down the words into sounds; it's a natural component of language. If we spoke in complete babble, we'd still be using phones which could be grouped into phonemes.
But that's not what you said. Until someone introduced the idea of a palantype, you were still explaining your idea as something where you'd type all the letters of the word simultaneously. Nothing was in that about using shorthand or a different set of symbols. There was also nothing to indicate this would be intended for a specialized market, such as court stenographers, until the palantype was mentioned.
Each time someone has mentioned an objection to the design you described, rather than discuss that or attempt to address that objection or get recommendations of ways around it, or even to clarify the intended market (I know I've mentioned that the objections you're getting here are that of the tech-saavy market, and that you'd hit more obstacles in the average consumer market; at that point you could have clarified that's not the market you had in mind, which would have been helpful to the discussion), you've just told us it's not really an issue and ignored the problem.
I have offered a recommendation on revising your idea based on the criticisms and your later acknowledgment that the palantype machine is something along the lines of what you were thinking about and targets the sort of market you were thinking about, and that is to study up on linguistics before designing something new. The criticism of your original design, which has been expressed by everyone who has posted in this thread, so appears to be a common issue, is that it requires typing in a way that is unnatural to the way people think. This is not going to get someone to speed up typing if they have to stop to think about every word they type. Use what linguistics has learned about how people use language to design your keyboard in a way that more naturally accommodates how we use language and it will be faster to use and easier to learn to use.
The long history of shorthand
"NCRA-approved programs require students to capture a minimum of 225 words per minute."
http://www.allcriminaljusticeschools.com/faqs/courtreporter.php
Palantype uses shorthand and phonetic syllabication. You, differently, proposed typing all of the letters of words, as we normally do, only all at once instead of one at a time.
Shorthand is tried, proven and works great. Shorthand with automatic computer expansion later came to be called macros. This is the origin of the name of Richard Stallman's text editor, Emacs.
http://www.google.com/search?q=macros+emacs
I use macros on my Twiddler. I can hit a one- or two- or three- or four- or five- finger chord and a programmed macro of any length matching that chord gets spit out into the computer. If you are going to memorize chords, why memorize long ones, and especially, why memorize long ones that require you to recall the exact spelling of a given word in less than one third of a second? As you said, the chord should just pop into your head and your fingers should chord it just by thinking of the word. This is what it is like to chord macros on a Twiddler. I can think of the words and my fingers automatically, ultra-rapidly, and precisely chord them without any thought to how they are spelled (I have the most common words I use programmed into my Twiddler so I can use them this way; otherwise I spell out my twiddled words, or I use macros for common word beginnings and endings; however, if I wanted to I could program my Twiddler to be a one-handed Palantype machine and easily exceed 225 WPM twiddling shorthand phonetic syllables and being able to completely ignore spelling - and a Perl script might be written to automatically translate this Palantype shorthand into English).
Why does your chording system insist on including irrelevant letters that make your chords phenomenally large and complicated?
Moonbear, technically the sounds we use when we speak are amplitude variations in air pressure waves. Do we think in terms of amplitude variations in air pressure waves?
Point is, you can break down the sounds all you want for your theory, but nobody actually does that when they speak or think, unless they have been trained in a system such as Palantype.
I quote from myself, post #19 in this thread:
Bartholomew said:
This would obviously only be for people who need or want to type fast. Secretaries, for example, might get a lot of use out of it, and people might use it for internet chat rooms. Scientists might not care; authors might like it. It wouldn't change anyone's life but it could be nice for a lot of people.
Also, from post #25 in this thread:
Bartholomew said:
This could never be a mass-market product, but authors might pay a few thousand dollars for a customized, ultra-fast keyboard.
What do you say to that?
The objections have ranged from the silly ("oh no, the average rate of words in a song is well below 100 wpm, you can't possibly type that fast"--paraphrase of Omagdon) to the uninformed (brewnog's last comment). Enough.
And the whole point of any machine shorthand system (which my idea has been from the beginning, whether recognized as such or not) is, you do not think about what you type if you have already memorized how to do it.
Yeah, the Phoenix system claims speeds of 240 wpm.
My system is probably not quite as good as the current methods of machine shorthand. But it's not very different, and (speculatively) might out-perform machine shorthand for typing from a manuscript, where you have letters in front of you instead of phonemes. You'd simply learn letter groups and the keys associated with them, instead of syllables and the keys associated with them.
You could get to memorize them as quickly as syllables, particularly if you're typing from a text which would jog your memory. The disadvantage is that there are more common syllables than common letter groups.
And no, my system doesn't insist on including extraneous letters; that's the way I formulated it, but nobody suggested cutting down on the letters to be used. It would be somewhat harder to learn if you cut out extraneous letters (because you lose the direct correspondence between word and keys), though in the end faster.
No, that's not how we think, and has nothing to do with my point about phonemes, which is how we think about words. I say sounds and I hear sounds that have meaning to me. Phonemes are collections of sounds that convey meaning.
No, I've never been trained in palantype, but do know what sounds I hear when I'm speaking. Even when I'm typing, I'm "hearing" the words in my head. Spelling approximates sounds, but not as precisely as phonemes do.
Right, your example included things like people using it for internet chat rooms. That hardly sounded like you were considering it to be something for only a specially trained group of people. You also said "it could be nice for lot of people. I suppose my interpretation of "a lot" is different than yours, and here we run into trouble.
One can memorize a lot of things, but it doesn't mean it will work when presented with a completely unfamiliar text to type. This is the proof you'll need to show if you want to show your keyboard is feasible. Whatever you come up with, as you're working on it, that's going to be the real test. It doesn't matter if you can practice until you're able to type all the words in your favorite song as they're being sung, you'll need to be able to type just as fast as someone dictates a letter you've never heard before, or presents you with a manuscript you've never read before, or when presented with words you've never heard of before. For example, in court, when someone is giving expert testimony and uses a technical term, the court reporter doesn't need to know how to spell it or know what it means, s/he can simply type the sounds s/he hears and read it back according to sounds. If you want this to even be useful to a niche market of court reporters and secretaries, you'll need to account for this. This is something that is also a limitation of the current way of typing on a QWERTY keyboard, because the secretary still needs to know how to spell the word, but has been addressed by the phoneme approach of the palantype. If your idea is going to take over that niche market, then it's going to have to do something even better than what the palantype does. If that's what you have in mind, then work on improving upon that rather than improving upon the QWERTY keyboard.
In post #30, I stated:
Moonbear said:
Keep in mind I don't want to make my laptop any larger than it is by adding more keys to the keyboard, so the same general shape and size or smaller is desired.
Your response in post #31, was:
Your response to my comment that the keyboard should be the same size or smaller, rather than being taken into consideration, was rejected as lacking faith. I don't lack faith in the powers of the mind, I lack faith in a "significantly larger" keyboard finding any market, other than maybe among collectors of odd inventions. I'm quite aware of the limitations of the human mind. I'm no expert in linguistics, which is why I've repeatedly suggested you learn more about it, because I can't teach it to you, but I do have some familiarity with the field and how we develop and process language from a neurological perspective. So, when you met the first comment about keeping the keyboard size small with such incredulity, why would anyone else bother to suggest ways to make it smaller. You didn't communicate that you were open to that suggestion, quite the opposite.
How many licks to get to the center of an eight-finger chording keyboard
Bartholomew said:
My system ... might out-perform machine shorthand for typing from a manuscript, where you have letters in front of you instead of phonemes.
Why, in the first place, would you type from a manuscript instead of scanning it?
This is what we already do with current chording keyboards. (A major difference is that current chording keyboards do not have the literal one-for-one correspondence between keys and letters that your keyboard has, but you do not seem to have explained why that might be important other than to effect user-friendliness for newbies.) You can program thousands of common-letter-combination macros for dual-handed chording keyboards, and you can reach them without changing your hand position since so few keys are needed (with three keys per finger, and counting no-key-press as a possible letter in a chord, there are four possible letters per finger per chord and therefore with eight fingers a total of [itex]4^8-1=65535[/itex] possible chords — all on a keyboard a tiny fraction of the size of a typical laptop keyboard).
Moonbear, I think it should be clear by now that YOU would not be part of the target demographic for this product. Therefore... I don't care what you want in a keyboard. The keyboard would be large enough to include all the letters, plus duplicates of those that commonly appear in duplicate. If you have a great idea that would make it smaller, please speak up; otherwise stop making demands about a product you'd never be part of the demographic for.
Also, I quite rightly supposed that you would offer no apology for assuming the product to be for general use when early in the discussion I stated twice that it would not be.
hitssquad: A handwritten manuscript would not scan well, so it would be more efficient to type it rather than scan it (if you don't want to have to work with an entire image). Even nowadays there are still typing services that you can send your papers into and they will type them up.
You raise a good point in your second paragraph; the essential difference between my proposed keyboard and a standard set of macros is that the "macros" on mine would be easier to learn and probably take longer to use (due to requiring more fingers in motion at a time), once fully learned. I don't know the respective weights of the advantage and the disadvantage.
For good typists, the limiting factor in typing from handwritten manuscripts is not typing speed, it is the speed with which you can read the handwriting. It is rarely possible to read handwritten manuscripts faster than one can speak.
The cutting edge in technology now, by the way, is in skipping the transcriber all together and having the computer take the dictation itself. It is close, but not quite there now.
Also, while being able to type a couple hundred words a minute has value to a court reporter, few court reporters have any need to type much faster. Getting input at 300-400 words per minute is rare. If there was a demand, someone might come up with a way to do it. But, in the absence of demand, there is no reason to make the technology any better than it is.
Quite frankly, even in court, it is becoming far more common to use tape recorders instead of a court reporter, since it is much, much cheaper.
Bartholemew, you're getting extremely defensive here.
If you want to develop a product, you research your market. You've bounced some ideas around here, and I think we can conclude that you wouldn't sell many of your keyboards as you have described to us. However, you are very unreceptive to the feedback you've had from the people here, and that's fine.
I suggest you consider exactly which demographic you expect to use such a contraption, and go and ask them what they think. Go to "secretaryforums.com", "authorforums.com" or "transcriberforums.com"*, and if their reaction is contradictory to what you've had here, then you may well be justified in being smug, especially if you manage to persuade someone to fund the development and manufacture of your keyboard.
Otherwise, dodging peoples' issues is not going to convince us, and a lack of understanding of/sympathy for a target market has been the cause of many business collapses in the past.
By all means, present your device to Logitech or Microsoft or whoever you wish, convince them as you have tried to convince us, and let the professionals decide. If you're utterly convinced that your product is feasible and viable, why haven't you patented it yet?
I sincerely wish you every success in your venture.
* - these forums may not be entirely real.
In the United States, any single patent costs ~$5,000 and a lot of work. Patents also have time limits, making them worthless shortly after they are granted, or worse than worthless in cases where critical process secrets are detailed in the patent.
http://www.cyberspaceattorney.com/guideview.asp?layer=2&article=214
A patent will give you a total monopoly on your product or process so that no one can use it, manufacture it or sell it without paying you money. But the downside is that you have to reveal all the secrets. You spill the beans about how it works. And when its 20-year limitation expires, your monopoly ends.
That does not sound like $5,000 well spent, does it, Brewnog?
On the contrary. If Bartholemew is convinced that he can successfully market this device, it will be money well spent, especially when he has some large computer peripherals manufacturer buying him out! I was pointing out that since he's not willing to make this step (or otherwise go about developing and marketing his device), he clearly has doubts about some aspect of his machine which he does not wish to admit to.
All I was saying is that if he's not going to take any constructive criticism made about his idea, putting his money where his mouth is might help.
Technically, they are amplitude and frequency variations mr. smarty-pants. :-p
Wow. My first use of one of those stupid little icons.
Because he does not have a patentable concept. No new technology and similar products already on the market are the key reasons I say that. His concept has evolved as this thread has progress, unfortunately (IMOH) it has gotten steadily worse! Initially he was simply hitting multiple keys simultaneously, now he has a whole new keyboard, which he already knows the size of, without having any idea as to exactly how many keys or what they will represent... Hmmm Horse before the cart? :rolleyes:
He doesn't want my input anymore, so I'm just replying to Integral and others who have commented on patents. :rolleyes:
Patentability doesn't translate into marketability. I was just on the phone a couple days ago with a friend who works as a patent attorney (I actually have two friends working in the same office, so hear a lot about patent law). He was telling me about the bizarre things that get patented (he said his clients include scientists, bad scientists, and crazy inventors, mostly the third one). You could probably get patent protection for a unique keyboard, though, it would be a very limited patent. Since keyboards exists in a variety of styles and technologies already, you can't patent the concept of a keyboard, you could only get protection on your specific configuration of a keyboard. Which means, all someone needs to do is add one more key somewhere, or take away a key somewhere, or switch around two keys, and you're not protected. This is similar to what people patent for ballpoint pens. You can't patent a pen, but you can patent a new barrel design, or a new ink formulation. Such patents are extremely limited.
If you file the patent yourself, filing it costs around $1000, which, depending on how wealthy you are, may be a drop in the bucket or a significant amount of money to spend on something that won't offer much protection. That $5000 estimate is probably what you'd pay if you went to a hack law firm, the kind that will fill out your application for you, but not help you with research or bother finding all the loopholes, etc. If you have a really good idea and want to protect the concept and get a good law firm to help with the research of prior art, write it so it holds up when you prosecute someone infringing on it, help with the technical drawings, etc, you're looking at a starting cost of $10,000 on up.
hitssquad is right that there's a risk in obtaining a patent, in that it reveals completely the mechanism of how something works, so your competitors can start working on using that idea as soon as the patent expires. Depending on who your competition is and what the market is like, sometimes it's advantageous to not patent something if it's likely to take your competitors longer to figure out how it works for themselves (business decisions sometimes involve some gambles), or to wait until you're just about ready to put it on the market before you file for protection (you're protected as soon as the filing is in, which is why a lot of things go to market labeled "patent pending"). And for some companies, patenting a new product line would reveal the gaps in protection of an already existing patent they hold, so it's better not to patent the new product and open opportunties for the competitors to jump in and use those gaps to their advantage.
There's a good lesson here about the job of an engineer too. If a client knew how to make exactly what they needed, or even knew exactly what they needed, they wouldn't need to hire an engineer to help. However, there needs to be good communication between the engineer and client to ensure what is being designed will work for what the client really wants to do with it. Sometimes you're going to get feedback that's disappointing ("No, that's just not going to work") and the client, not being an engineer, isn't going to be able to tell you what will work, just that they know what you've shown them isn't it. It's the job of the engineer, not the client, to come up with the solution to the problem. If the engineer gets defensive and doesn't listen to the client when told things are wrong, it's going to lead to disaster. Something that may be really fun to design and build just might not be appealing in the marketplace. Isn't the continuing struggle for communication between marketing depts and engineering depts the entire basis of the Dilbert cartoons?
