How to calculate energy stored in a parallel-plate capacitor?
  • Thread starter Thread starter ajmCane22
    Capacitor
The discussion focuses on calculating the energy stored in a parallel-plate capacitor with an area of 383 cm² and an initial separation of 1.51 mm, charged to 575 V. The correct formula for capacitance is C = εA/d, and energy is calculated using E = 1/2CV². The user correctly calculated the energy for part (a) as 3.712e-5 J but encountered errors in parts (b) and (c) due to misunderstanding the changes in voltage and capacitance when the plate separation is increased to 4.53 mm. The charge remains constant while voltage changes, affecting the energy calculations.
  • Understanding of parallel-plate capacitor theory
  • Familiarity with the formulas for capacitance (C = εA/d) and energy (E = 1/2CV²)
  • Knowledge of how voltage and charge interact in capacitors
  • Basic algebra for manipulating equations
  • Review the concept of electric field strength in capacitors
  • Learn about the effects of dielectric materials on capacitance
  • Study the relationship between charge, voltage, and energy in capacitors
  • Explore practical applications of capacitors in electronic circuits
Students studying electrical engineering, physics enthusiasts, and anyone seeking to understand capacitor energy storage and the effects of changing plate separation.
ajmCane22
A parallel-plate capacitor has plates with an area of 383 cm2 and an air-filled gap between the plates that is 1.51 mm thick. The capacitor is charged by a battery to 575 V and then is disconnected from the battery.
(a) How much energy is stored in the capacitor?
(b) The separation between the plates is now increased to 4.53 mm. How much energy is stored in the capacitor now?
(c) How much work is required to increase the separation of the plates from 1.51 mm to 4.53 mm?
Please, explain your reasoning.
This is what I did:
C = εA/d to find C and then used E = 1/2CV^2 to find E. Then for part (c) I subtracted the value for part (b) from the value for part (a). I got the following values:
(a)3.712e-5 J
(b)1.236e-5 J
(c)2.476e-5 J
(b) and (c) are incorrect and I'm not sure what I'm doing wrong. (a) and (b) should be the same equation, correct? I don't understand why I'm getting part (a) right and part (b) wrong. Please help.
When the plates are separated by some additional distance, which of the quantities Q, C, V remain the same and which ones change?
Oh! The voltage changes, so I need to calculate the second voltage, right?
Yes, the voltage changes but the charge remains the same.
  • · Replies 18 ·
  • · Replies 28 ·
