Equations of Parallel Tangent Lines to f(x)=3x(5x^2+1)
The discussion focuses on finding the equations of tangent lines to the function f(x)=3x(5x^2+1) that are parallel to the line y=8x+9. The derivative of the function is calculated as f'(x)=45x^2+3, leading to the identification of points where the slope equals 8. The points of tangency are found at x=±1/3, with corresponding function values of f(1/3)=14/9 and f(-1/3)=-14/9. The resulting tangent line equations are y=8x+10/9 and y=8x-10/9. The importance of verifying calculations by plugging values back into the original function is emphasized throughout the discussion.
Physics345
Determine the equations of the tangent lines to the graph of f(x)=3x(5x^2+1) that are parallel to the line y=8x+9
y=m(x-x_1 )+y_1
11.f(x)=3x(5x^2+1)
The slope of the tangent line y=8x+9
f^' (x)=3(5x^2+1)+3x(10x)
f^' (x)=15x^2+30x^2+3
f^' (x)=45x^2+3
Finding the point of tangency:
m=8
8=45x^2+3
5=45x^2
√(x^2 )=√(45/5)
x=±1/3
f(1/3)=(3(1/3))(5(1/3)^2+1)
f(1/3)=1(5(1/9)+1)
f(1/3)=5/9+9/9=14/9
f(1/3)=14/9
f(-1/3)=(3(-1/3))(5(-1/3)^2+1)
f(-1/3)=-1(5(1/9)+9/9)
f(-1/3)=-1(5/9+9/9)
f(-1/3)=-14/9
y=m(x-x_1 )+y_1
y_1=14/9 x_1=1/3 m=8
y=8(x-1/3)+14/9
y=8x-8/3+14/9
y=8x-24/9+14/9
y=8x-10/9
y=m(x-x_1 )+y_1
y_1=-14/9 x_1=-1/3 m=8
y=8(x-(-1/3))-14/9
y=8x+8/3-14/9
y=8x+24/9-14/9
y=8x+10/9
Therefore, the equations of the tangent lines are y=8x+10/9 and y=8x-10/9 I'm pretty sure I did this correctly, but I'm not confident in my final statement.
You seem correct.
Likes Physics345
It looks good to me. After all those calculations, it's good to plug numbers back in and make sure it works as advertised: At x=1/3, does f' = 8 and f(x) = 3x(5x^2+1) = 8x+10/9? Do the same type of checks for x=-1/3.
Likes Physics345
Of course, I did that on paper, but I thought it would be pointless, to show to the teacher when I handed in my work. Especially since my teacher understands my enjoyment and capabilities when it comes to math. Thanks guys, I appreciate your advice.
Likes lekh2003
You said that you were not confident in your answers. Plugging the numbers back into verify that the answers are correct should have given you confidence.
The one exception is in the slope of 8, which depends on whether you calculated the derivative correctly. That is hard to verify by plugging numbers directly into f(x) except by plugging in x=1/3 and something like x+Δx = 1/3+0.001.
Likes Physics345
Plugging in numbers back again is a very fast way to figure out whether your answer is right, especially under time-intensive conditions or when the actual working is so long that you need an alternative method rather than skimming the working.
I just today used the technique of plugging the numbers back into the start in a long time-intensive financial math test, where most of the working is hidden in the calculator.
Oh I was referring to my therefore statement when I said that sir, and when I said "I'm pretty sure I did this correctly" I was referring to the math and using "pretty sure" was my scapegoat in case my math was somehow wrong in a way beyond, my spectrum of understanding. Sorry for the confusion! I have a problem conveying my thoughts through writing, it's something I've been working on a lot lately.
Yes of course, I completely agree. The number one rule of doing math is checking your work, since there is always a way to do it in algebraically when it comes to functions, and by "always" I mean in relation to my current level of math.
Ha! I can really understand that! Being able to write clearly is something I have struggled with all my life. It's very good that you recognize how important that is.
Likes Physics345
Oh, I've always had this problem as well, unless I spend endless hours reviewing/refining what I write. I wish there was a easier solution, but I tend to rush into things without thinking, which I have found extremely hard to stop. Do you have any techniques or advice that could possibly help me out? I honestly thought I was crazy and this wasn't normal, I'm glad I found someone that can relate to my problem.
Just keep word-smithing your work to make it clearer. Eventually I learned what bad habits I have and look to correct those. I usually have to break up very long sentences and replace ambiguous pronouns with the specific nouns.
Likes Physics345
That's what I've been doing for a while now, it just takes a very long time. I guess eventually I'll be able to speed up the process with practice and time.
