Mentor
- 50,837
- 26,842
Jufa said:In the sphere example, which I have seen everywhere, I don't know which is the rule to choose the local reference frame at a certain point of the curve.
There is no such rule. You can choose a local reference frame any way you like. Trying to think about parallel transport in terms of "which local reference frame" will only confuse you--as, indeed, it has throughout this thread.
To understand parallel transport, you need to forget about reference frames entirely and think about what is happening, geometrically, to vectors as they are transported along curves. Only once you understand that, without making use of reference frames at all, can you then go back and apply that understanding to transporting particular vectors you are interested in, such as the set of vectors that happen to be basis vectors of some chosen reference frame at some particular point.
Jufa said:Let us consider the physical quantity ##A^{\mu}(x^{\nu}_0) e^\alpha_{\mu}(x^\nu_0)## which it is obtained by evaluating the vectorial field ##A^{\mu}(x^{\nu})## at ##x^\nu_0##, considering a local reference frame defined by the basis vectors ##e^\alpha_{\mu}(x^\nu_0)##. This basis vectors, in contrast with the coordinates ##A^{\mu}(x^{\nu}_0)##, refer to an actual physical quantity and, therefore, do not depend on the reference frame chosen.
The basis vectors, as vectors, are geometric objects independent of coordinates, yes. But that is not the same as saying that if you take those vectors, which are basis vectors at point p, and transport them along some curve to point q, they will still be basis vectors at point q. Whether or not that is the case is a choice that you can make either way--because it is equivalent to choosing local coordinates at q, which is a choice independent of your choice of local coordinates at p. The geometry of the situation, including the geometric properties of parallel transport, tells you nothing about such coordinate choices, which is why I keep telling you to forget about coordinates and reference frames and concentrate first on understanding the geometric properties involved.
What you should be looking at here is the inner product between the two vectors ##A## and ##e^\alpha##, which is what the expression you wrote down represents. If we assume that ##e^\alpha## is the tangent vector to the curve you want to transport along, then the inner product between ##A## and ##e^\alpha## tells you the angle of ##A## relative to the direction along the curve. And parallel transport will keep that angle the same as both vectors get transported along the curve (assuming the curve is a geodesic). That is a key geometric property that you need to understand.
Now, consider the sphere example again. Suppose we start out at point p on the equator, with the vector ##A## pointing towards the North Pole, which is along the first geodesic segment we want to parallel transport along. Then ##A \cdot e^\alpha = 1## at p (assuming both vectors are unit vectors), and that property will be preserved by parallel transport, so when we reach the North Pole, we will have ##\tilde{A} \cdot \tilde{e}^\alpha = 1##, i.e., the parallel transported vectors will still point in the same direction.
Now we switch curves, which may be where some of your confusion is happening. Our second curve segment is at right angles to the first, so it has a different tangent vector, ##e^\beta##, which makes a different angle with our chosen vector ##A## than ##e^\alpha## did. In fact, since the curve is at right angles to our original one, we will have ##\tilde{A} \cdot e^\beta = 0##. Notice that this statement, just like the statement that ##A \cdot e^\alpha = 1##, has nothing to do with any choice of basis at the North Pole. The key point is not that any basis has changed, it's that we've changed curves, so the tangent vector has changed, so the angle between the tangent vector and ##A## has changed.
Now we transport along our second curve back down to the equator; call the point we reach on the equator point q. Parallel transport will preserve ##\tilde{A} \cdot e^\beta = 0##, so that will still be true at q. At q, we switch curves once more, our third curve being the equator, so we have a third new tangent vector, ##e^\gamma##, at right angles to ##e^\beta##, and therefore we have ##\tilde{A} \cdot e^\gamma = -1##. We then transport along the equator back to point p. And we find that the transported vector ##A## is now at right angles to the original vector ##e^\alpha##: we have ##\tilde{A} \cdot e^\alpha = 0##. Or, since the original vector ##A## pointed in the same direction as ##e^\alpha##, we can say that parallel transporting around the closed curve has changed the vector ##A## by a right angle; the inner product of the transported vector with the original vector vanishes: ##tilde{A} \cdot A = 0##. And note, once again, that I reached this conclusion without talking at all about any coordinates or reference frames or basis vectors. I only talked about invariant geometric properties: tangent vectors to curves and inner products of vectors.
