Parameter μ dimensional regularization qed
The discussion revolves around the parameter μ in the context of dimensional regularization in Quantum Electrodynamics (QED). Participants explore its role, physical meaning, and implications for renormalization, particularly when extending from four-dimensional Minkowski space to D-dimensional space.
  • Some participants inquire about the physical meaning of the parameter μ, questioning how it can be fixed and its significance in the Lagrangian density.
  • Others explain that μ is absorbed into renormalized coupling constants and field renormalization.
  • One participant expresses confusion about the relationship between μ and the mass of the photon, noting that the photon mass is taken to be zero at the end of calculations.
  • Another participant clarifies that μ is introduced to ensure the Lagrangian density has the correct physical dimension in D dimensions.
  • There is a discussion about how finite terms dependent on μ arise and whether there is a method to resolve or fix μ.
  • Some participants agree that when D=4, μ does not play a significant role and is primarily a tool for regularization.
  • One participant mentions that physical parameters must transform appropriately under changes in μ, relating this to the concept of the renormalization group (RG).
Participants generally agree that μ serves as a tool for dimensional regularization and does not affect the physical Lagrangian when D=4. However, there is no consensus on how to fix or interpret μ in terms of physical significance, with multiple viewpoints and uncertainties expressed.
Limitations include the dependence on the definitions of terms and the unresolved nature of how to fix the parameter μ in practical applications.
paolorossi
in the dimensional regularization of the QED we introduct an arbitrary parameter μ with the dimension of a mass... so there are finite terms that are function of μ... so they are arbitrary? how we can fix this parameter? what is the physical meaning of μ?
They are absorbed into the renormalized coupling constants and field renormalization.
a book to view this?
Do you mean for photon mass which is definitely taken zero at the end of calculation because the integrals are divergent without it and photon should not have any mass.
I speak about the parameter μ that we introduct in the extension of the 4 dimensional minkowsky space to a D dimensional space. This parameter is such that the Lagrangian density of interaction has the correct physical dimension MD in D dimensions.
But when we return to 4 dimension some terms depend on μ. xepma say that
, but how I can see that? can somebody suggest a book or paper?
(sorry for my english)
So what exactly is μ.
Is it a question?
μ is the arbitrary parameter, with mass dimension, which appears in the Lagrangian density of interaction in D dimesion
LI = e μ 2-D/2 [itex]\bar{\psi}[/itex][itex]\gamma[/itex][itex]\mu[/itex][itex]\psi[/itex] A[itex]\mu[/itex]
so that LI has the correct dimension MD (note that the fields have the dimension [ A[itex]\mu[/itex] ] = MD/2-1/2 , [ [itex]\psi[/itex] ] = MD/2-1 ).
My question is: if the counter-terms are such that only the divergent terms are "eliminated" in the corrections to higher orders (propagators and vertex) , then there are finite terms that are function of μ. But μ is arbitrary. So how do you solve this? maybe there is a way to fix μ?
it is clear that when D=4(as is the case) ,μ does not play any roll after all.But only a tool to handle regularization in arbitrary dimension.(I thought it to be some photon mass type thing which is taken zero at end)
yes, what you say is correct, in fact, the bare interaction Lagrangian density will not have to depend on the parameter μ (in the limit D=4) ... so if we express the lagrangian in terms of physical quantity (renormalizated charge, mass , ... ) then these physical parameters must transform adequately under a change of the parameter μ, so that the theory (ie the amplitudes calculated) are independent from the choice of μ. that is, if we make the transformation
μ -> μ'
then, for example, the charge change as
e(μ) -> e(μ')=e'
so that, for example, the vertex (plus radiative corrections) remains unchanged. I saw that the set of this transformation forms the so-called " renormalization group" (RG). thanks anyway for answer!
  • · Replies 22 ·
  • · Replies 134 ·
13K
