Parametric Equation Differentiation
18 replies · 8K views · last reply
thomas49th
A curve has parametric equaions:
x = 2cot t, y = 2sin²t, 0 < t <= pi/2
Find an expression for dy/dx in terms of the parameter t
Not sure where to go. Do i need to make a Cartesian equation first?
Hi thomas49th! :smile:
Hint: what is dy/dx in terms of dy/dt and dx/dt? :smile:
dy/dt = 2cos²t
dx/dt = -2cosec²t
is that right?
thomas49th said:
dy/dt = 2cos²t
dx/dt = -2cosec²t
is that right?
dy/dy is incorrect don't forget chain rule!
dx/dt is right.
No!
[tex]y=2\sin^2 t[/tex]
[tex]\frac{dy}{dt}=4\sin t\cdot\frac{d}{dt}\sin t[/tex]
[tex]4\sin t\cdot\frac{d}{dt}\sin t[/tex]
= 2sinxcosx
now where do i go?
Thanks
Think how to get [tex]\frac{dy}{dx}[/tex] on its own. Basically eliminating the [tex]dt[/tex].
Any ideas?
= 2sinxcosx
now where do i go?
Thanks
Your constant is wrong.
Now you answer tiny-tims original question:
Remember that, even though "dy/dx" is not a fraction, it is defined as the limit of a fraction, and you can always treat it as if it were a fraction.
dx/dt = -2cosec²t
dy/dt = 4sin(t)cos(t)now i don't know how to lay it out but i remeber somthing about flipping dy/dx around and everyone going you can't do that in the class. Can you show me?
Thanks
thomas49th said:
dx/dt = -2cosec²t
Thanks
Draw a diagram …
x = 2cot t, y = 2sin²t, is a curve.
Draw any old curve, and pretend it's the right one.
Now makes some marks on the curve to indicate equal amounts of t.
Draw a right-angled triangle connecting two of those marks … one side along the curve, and the other two parallel to the x and y axes.
Then dy/dx is the gradient (slope) of the long side, isn't it?
And dy/dt is the right-hand side divided by the change in t.
And dx/dt is the bottom side divided by the change in t.
So (dy/dt)/(dx/dt) is the right side divided by the bottom side … which is the tangent of the slope of the long side … which is dy/dx … isn't it? :smile:
Try dividing one equation by the other, but which one?
(dy/dt) / (dx/dt)
= dy/dt * dt/dx
= dy/dx
yes yes. so now where. That was fun!
Thanks
thomas49th said:
That was fun!
Maths is fun sometimes! :biggrin:
so now where.
So now apply your fun formula to:
thomas49th said:
dx/dt = -2cosec²t
:smile:​
ahhh i see
[tex]\frac{dy}{dx} = \frac{4\sin t \cos t}{-2cosec^{2}t}[/tex]
which can be simplified to
[tex]\frac{dy}{dx} = \frac{-2\cos t}{\sin t}[/tex]
[tex]= -2 \cot t[/tex]
Is that right?
thomas49th said:
ahhh i see
Is that right?
erm … 1/cosec²t = sin²t. :rolleyes:
So dy/dx = … ? :smile:
o yea! I mean -2sin³t cost
easy
Ok. Now for the next bit i need to find the tangent where t = pi/4
For this should i get all trig terms the same using trig identities i know or sub t= pi/4 in straight away.
