Parametric Equation of Surface
  • Thread starter Thread starter Phil Frehz
    Parametric Surface
5 replies · 3K views
Phil Frehz
Find parametric equations for the portion of the cylinder x2 + y2 = 5 that extends between the planes z = 0 and z=1.
I can't really find any connection but I do have
x=a*sinv*cosu
y=a*sinv*sinu
z=a*cosv
I understand that there is a cylinder of radius 5 between z=0 and z=1 however I don't understand how to translate it in terms of u & v. In polar coordinates I know r extends from the origin (r=0) to the cylindrical curve (r=1), while theta is from 0 to 2pi.
Attached is the solution, not sure how to connect the information together
x=a*sinv*cosu
y=a*sinv*sinu
z=a*cosv
Just focusing on the circle in the x-y plane for the moment, think about how you would translate the circle's equation into polar coordinates. That should give you equations for x and y in terms of a parameter. The inequality for z is very simple, with v = z, but within a limited interval.
Thanks for the input, I looked into it and found that v was the varying parameter, converting x and y to polar coordinates gave me the answer. Thanks again
x=a*sinv*cosu
y=a*sinv*sinu
z=a*cosv
Is x2 + y2 = 5 the equation of a cylinder of radius = 5?
https://en.wikipedia.org/wiki/Circle
That's how the book stated the problem, I understood it as the cylinder created when the circle x2 + y2 = 5 is extended between z=0 and z=1
Since the sections thru the cylinder along the z-axis are circles, then the equation of the circle,
namely x2 + y2 = r2, must be satisfied.
If the radius of the circular sections of the cylinder is indeed r = 5, then what must the equation of the cylinder be?
