Parametric equation true/false
  • Thread starter Thread starter -EquinoX-
    Parametric
5 replies · 9K views · last reply
-EquinoX-
(a) The parametric curve x = (3t + 4)2, y = (3t + 4)2 - 9 for 0 t 3 is a line segment.
(b) A parameterization of the graph of y = lnx for x > 0 is given by x = et, y = t for - < t < .
(c) The line parameterized by x = 8, y = 5t, z = 6 + t is parallel to the x-axis.
a. false
b. true
c. true
Is my answer correct? If its false can someone help me to explain why
You should provide the reasoning behind your answers.
for part a, it's just a mere guess as I see a ^2 there, so I thought it wouldn't be a line
for part b I think because when you plugged in the graph you get the same
for part c, the two lines aren't multiples of each other... 5j + k and 1i
For equation 1, try finding an equation for y in terms of x. It should be pretty easy. Then you'll easily see whether it's a line or not.
Actually, the way you wrote it, there is NO "^2".
A way of seeing that it is not a line is to choose three values of t giving three points on the graph. Find the slopes between two pairs of points. If they are not the same, it is not a line.
That sentence doesn't make sense to me. How do "plug in" a graph? And what does "the same" refer to?
Because the "two lines aren't multiples of each other", you say the line is parallel to the x-axis?
