Partial Derivative: Chain Rule
17 replies · 3K views
iamyes
2 straight roads intersect at right angles. Car A, moving on one of the roads, approaches the intersection at 60km/h and car B moving on the other road, approaches the intersection at 80km/h. At what rate is the distance between the cars changing when A is 0.5km from the intersection and B is 0.7km from the intersection?
None. Dont know how. Dont give me the solution, give me a clue i want to try to solve it.
1. Let the intersection be the origin in your coordinate system.
2. Now, let A's position at t (hours)=0 be 0.5 (km) on the right-hand side of the origin.
Then, A's position vector as a FUNCTION of time, A(t) will be:
[tex]A(t)=(0.5-60*t,0)[/tex]
(Agreed?)
Can you set up a similar vectorial position function for B?
3. Now that you have both position functions, how can you find the DISTANCE function, D(t) between them? (Hint: Pythagoras..)
4. You are asked for the rate of change for D(t).
How can you find that?
so..
2) B(t) = (.7 - 80*t , 0)
3) D(t) = (.5^2 + .7^2)^1/2
i can't figure out this one...--->> 4)You are asked for the rate of change for D(t).
2. is wrong, it should be: B(t)=(0, .7-80t)
3. is doubly wrong, since it
a) only gives D(0), rather than D(t)
and
b) calculates it incorrectly from the A(t) and (incorrect) B(t) you set up.
if.. i do it my way, i got the final answer is -100km/h..
is that same as yours?
Post your way, please.
i got dX/dt = -100km/h
That is indeed correct! :smile:
hurmm.. I'm still wondering why did my lecturer told me that there's something
wrong with my solution..:frown:
Well, if you used YOUR version of D(t), then it is a totally incorrect procedure.
The rate of change of THAT expression is just 0.
naspek said:
so..
did u mean by the above D(t)
Quite so.
That function is equal to a constant, its derivative is..0
just for final confirmation...
my calculation and my answer for this question is totally correct
right?
Not if you specified D(t) in the manner YOU did, no.
The answer won't follow from that at all.
could anyone pls give me the solution?
damn I am stuck and it is 3.30am over here
Then follow my hints in post 2.
They are sufficient.
yeah i read all this thread..but still can't do it (im stupid :( )
if anyone could go through everything once again i would be thankful
i can't do it :(
im stupid
and i don't know anything on how to do it
