What Is the Correct Approach to Solving uxx = utt Using Separation of Variables?
The discussion focuses on solving the wave equation uxx = utt using the method of separation of variables. The initial attempt yields solutions for different values of λ: for λ = 0, a linear solution is obtained; for λ > 0, exponential solutions arise; and for λ < 0, trigonometric solutions are derived. The participants emphasize the importance of considering all possible values of λ and the implications of boundary conditions, noting that without them, the general solution can be expressed as a combination of functions of the form Af(x-t) + Bf(x+t). The conversation highlights the necessity of verifying solutions and the role of boundary conditions in determining the final form of the solution.
Jncik
solve uxx = utt
using the method of separation of variables I get
X''(x) - λ*X(x) = 0
T''(t) - λ*Τ(t) = 0
For λ = 0 I get X(x) = Ax + B where A and B are constants
T(t) = Dt + E where D and E are constants
hence u(x,t) = (Ax + B)*(Dt + E)
for λ>0 I get u(x,t) = [PLAIN]http://img690.imageshack.us/img690/8068/asdqu.gif [/URL] where c1,c2,C1,C2 constants
for λ = -b^2<0 I get (E*cos(bx) + F*sin(bx))*(G*cos(bt) + H*sin(bt)) where E,F,G,H constants
hence the solution
is from the superposition principle
u(x,t) = (Ax + B)*(Dt + E) + [PLAIN]http://img690.imageshack.us/img690/8068/asdqu.gif [/URL] + (E*cos(bx) + F*sin(bx))*(G*cos(bt) + H*sin(bt))please is this correct? i think its wrong, because I am not sure about the last part
also our professor has only the [PLAIN]http://img690.imageshack.us/img690/8068/asdqu.gif [/URL] as a reply, but i think its wrong, because we have to check for all λ to find all the possible solutions
λ is fixed. You either have λ > 0 or λ < 0, so you have either the solution
with exp[√(λ) x] or the one with the sines and cosines. Apart from that, you are correct but for one (I assume) typo: it's not exp[√(λx)] but exp[√(λ) x].
(PS: Of course you could also have λ = 0, but that appears seldom in reality.)
Note that given any function f, f(x-t) or f(x+t) satisfies this equation.
Are you given any boundary conditions?
thanks for your answers, no there are no boundary conditions
there is another exercise with boundary conditions and I get a simple result..
Without boundary or initial conditions, the most general possible solution is Af(x-t)+ Bf(x+t) where f is any twice differentiable function of a single variable, A and B constants, as phyzguy said.
That can be written in the form Jncik gives initially by summing over all possible values of \lambda.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 18 ·
