Particle collision and deflection angle
The discussion centers on calculating the deflection angle (θ) after a collision between two particles, A and B, where A has mass m and initial velocity v0, while B has mass 2m and is initially at rest. The conservation of momentum and energy equations are utilized to derive expressions for the velocities post-collision, leading to the conclusion that the angle θ can be determined using the equation θ = arctan(t), where t = tan(θ). The analysis reveals that the collision is inelastic, as energy loss (α) is linked to the deflection angle, with the condition that no more than one-third of the initial energy can be lost for real roots to exist in the derived equations.
  • Understanding of momentum conservation principles
  • Familiarity with kinetic energy equations
  • Knowledge of elastic and inelastic collisions
  • Ability to manipulate trigonometric functions and equations
  • Study the principles of conservation of momentum in two-dimensional collisions
  • Learn about the coefficient of restitution and its impact on collision outcomes
  • Explore the differences between elastic and inelastic collisions in detail
  • Investigate the role of energy dissipation in particle collisions
Physics students, educators, and anyone interested in understanding particle dynamics and collision mechanics.
geoffrey159
Particle A of mass m has initial velocity v0. After colliding with particle B of mass 2m initially at rest, the particles follow the paths shown in the sketch (see attachment). Find ##\theta##
collisions
The momentum before and after collision is
\left\{
\begin{array}{}
\vec P_i = mv_0 \hat \imath \\
\vec P_f = (mv_0' \cos{\theta} + \sqrt{2}m v_1')\ \hat\imath + (-m \sin(\theta) v_0' +\sqrt{2}mv_1')\ \hat\jmath
\end{array}
\right.
By conservation of momentum, ##v_0'## and ##v_1'## can be expressed in terms of ##v_0## and ##\theta## :
\left\{
\begin{array}{}
v_0' = \frac{v_0}{\cos(\theta) +\sin(\theta)} \\
v_1' = \frac{v_0}{\sqrt{2}} \frac{\sin(\theta)}{\cos(\theta) +\sin(\theta)}
\end{array}
\right.
Now in terms of energy:
## K_f = \frac{1}{2}mv_0'^2 + m v_1'^2 = \frac{1+2t^2}{(1+t)^2} K_i##,
where ## t = \tan(\theta)##.
The ratio between energy lost in the collision and initial kinetic energy is:
## \alpha = \frac{Q}{K_i} = 1 - \frac{K_f}{K_i} = \frac{t(2-t)}{(1+t)^2} ##
which can be re-written :
## (\alpha+1) t^2 + 2(\alpha -1) t + \alpha = 0 ##
The roots are real numbers only if ##\alpha \le 1/3## which is the same as saying that no more than one third of initial energy can be lost in the collision. In that case:
## t = \frac{1-\alpha}{1+\alpha} \pm \frac{\sqrt{1-3\alpha}}{1+\alpha} =
\frac{K_i - Q}{K_i+Q} \pm \frac{\sqrt{K_i}\sqrt{(K_i - 3Q)}}{K_i+Q}##
The answer will be ##\theta = \arctan(t)##, but which root should we keep ?
Look at your diagram, which would be consistent with momentum conservation?
The diagram suggests that ##\theta## is smaller than 45 degrees. So we should have ##0<t<\frac{\sqrt{2}}{2}##.
For exemple, the '+' root is not acceptable for ##\alpha = 1/6##, so I think we have to keep the '-' root. Right?
Sorry, I made a mistake, ##\tan(45) = 1## and not ##\frac{\sqrt{2}}{2}##, but I reach to the same conclusion. Do you agree ?
geoffrey159 said:
The diagram suggests that θ is smaller than 45 degrees. So we should have 0<t<2√20
I wouldn't trust the diagram to show which angle is greater.
I don't understand your elaborate algebra dealing with fraction of energy lost. Don't you need to assume perfectly elastic in order to get an answer? It says particles, so maybe this is as in subatomic particles.
Hello,
Energy may or may not be conserved, the text does not say, that is why the result depends on Q.
The fraction of energy lost (##\alpha##) is a convenient way to link Q with the deflection angle ##\theta##.
My result is consistent with perfectly elastic collision: take Q = 0 and keep the '-' root. You'll find that the angle is 0. Conversely, that angle conserves kinetic energy.
However, the bigger particle would be at rest after the collision, which is in contradiction with the diagram. So the collision is inelastic.
It depends what you mean by a result. Your answer has in it an unknown, Q, which you introduced. The question as stated gives you no permission to do that.
Also, there's no way the angle can be 0. That would mean momentum is not conserved in the j direction.
wait...
For an elastic collision, ##\tan(\theta) = 0## or ##\tan(\theta) = 2##.
First option is impossible because momentum is not conserved.
Second option gives ##\sin(\theta) = 2\cos(\theta) ##.
That gives :
##K_f = \frac{K_i}{9}(\frac{1}{\cos^2(\theta)} + 4) ##
By conservation of energy, and if there is no mistake, ##\theta = \arccos(\frac{1}{\sqrt{5}}) ## which is approximately 63 degrees.
But why do you assume elastic collision, I don't understand
Because the question does not give enough information, so you have to ask what is it they forgot to tell you. Elastic collision is a possibility. Since it describes the objects as particles, perhaps you are intended to interpret these as subatomic particles. Perhaps there is more context you are aware of that might support that?
it makes sense, because of the lack of context, the answer is open to discussion. Now assume that the collision is inelastic and that Q joules are dissipated during the collision. You said earlier that you do not use the diagram to pick a root or another (the case of elastic collision proved you were right)
How would you do then ?
Fixing on a number of Joules dissipated is not likely to make the algebra easy. Try fixing the coefficient of restitution instead. See what equation you get. Picking the root might be obvious from that.
  • · Replies 24 ·
