Particle Motion in a Magnetic field
The discussion revolves around the motion of a charged particle entering a uniform magnetic field, specifically when the y-axis is aligned with the magnetic field. Participants are examining the resulting equations of motion and the implications of the Lorentz force on the particle's trajectory.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the derivation of equations related to the motion of the particle, including the use of differential equations. Questions arise regarding the meaning of triple derivatives and the application of auxiliary functions in solving the equations. Some express confusion about the transition from differential equations to their solutions.
The discussion is active, with participants sharing their attempts and clarifying their understanding of the equations involved. Some have provided insights into integrating the equations, while others are seeking further clarification on specific steps and concepts, particularly regarding the use of auxiliary functions.
Participants note that the problem is derived from a textbook example, which lacks detailed explanations. There is an emphasis on understanding the mathematical techniques used, particularly in relation to the third-order differential equations presented.
Macykc2
Consider a charged particle entering a region of uniform magnetic field B - for example the Earth's field. Determine it's subsequent motion when the y-axis is parallel with the magnetic field
F=qv x B = ma
vector components of velocity, acceleration, and magnetic field
This isn't homework, it's an example from the book, but they skip many gory details that I can't seem to figure out, and the way we did it in class makes even less sense.
To cut a long story short, eventually I get two equations:
z'''=-α2z' and x'''=-α2x'
Then the book says they use the technique's used in appendix C, which are the use of Auxiliary functions (or characteristic) and homogeneous equations, which we aren't using in class apparently, I'd like to know how they are used and the examples given in the back make sense, but they are all 2nd degree functions, not 3rd like mine.
My attempt with the equations as they are:
r32r=0
which I can see 3 solutions from:
r=0, r=±iα
the second solution will yield the cos and sin functions I desire, but I'm missing a "t" that needs to be with the alpha in the trig functions and I have no idea how to get it.
x=Acos(αt) + Bsin(αt) + x0
z=A'cos(αt) + Bsin(αt) + z0 These two are the end results in the book
I feel as if though I'm supposed to integrate the functions first which will give me the initial position constants, but I don't know where the "t" comes from.
Are those triple derivatives? Why?
Can you just post a diagram of the situation, and show how the Lorentz force guides the motion of the charged particle?
Here are the pics straight from the book, I thought this would be easier than typing it out, hopefully they turn out fine.
Yoiks. Can you scan them and Upload them?
No sadly, I'll just type it out, give me a few mins
Thanks
Alright so the cartesian coordinate system is chosen with the y-axis parallel to the magnetic field. If q is the charge on the particle, v it's velocity, "a" it's acceleration, and B the Earth's magnetic field, then:
v=x'i + y'j + z'k
a = x''i + y''j + z''k
B = Boj
The magnetic force F=qv X B = ma, so
m(x''i +y''j + z''k) = q(x'i + y'j +z'k) X Boj = qBo(x'k - z'i)​
Equating like vector components gives:
mx''=-qBoz'
my''=0
mz''=qBox'​
Integrating the second of these equations, my''=0, yields:
y'=yo'​
where yois a constant and is the initial value of y'. Integrating a second time gives:
y=yo't + yo
where yois also a constant.
To integrate the first and last equations (the x'' and z''), let α=qBo/m, so that
x''=-αz'
z''=αx'​
These coupled, simultaneous differential equations can be easily uncoupled by differentiating one and substituting it into the other, giving:
z'''=αx''=-α2z'
x'''=-αz''=-α2x'​
so that
z'''=-α2z'
x'''=-α2x'​
Everything up to here makes complete sense, but it is the bridge between here and this next part that I can't figure out:
Both of these differential equations have the same form of solution. Using auxiliary functions and homogeneous equations, we have:
x=Acos(αt) + Bsin(αt) + xo
z=A'cos(αt) + B'sin(αt) + zo
Also I should add this isn't the final solution to the problem, it's just the step I'm having trouble understanding.
Macykc2 said:
z'''=-α2z'
x'''=-α2x'
Conside the equation ##x'''=-\alpha^2 x'##. If we define ##u=x'## then we can re-write it as
$$u''+\alpha^2 u=0.$$
The general solution to this, as you're probably aware, is:
$$u(t)=a\cos(\alpha t) + b\sin(\alpha t) = x'(t)$$
Now, just integrate the solution with respect to time, and we get
$$x(t) = A\cos(\alpha t)+B\sin(\alpha t) + x_0,$$
where, for example, ##A=-b/\alpha##.
Hope this helps.
