How is the particle's speed at points B and C determined?
The particle's speed at point B is calculated to be 5.77 m/s, while at point C, it is determined to be 6.261 m/s. This is derived using the conservation of mechanical energy, specifically the equation mgh = 1/2mv^2, where the initial potential energy is converted into kinetic energy. The net work done by the gravitational force from point A to point C can be expressed as the change in kinetic energy, W_NET = ΔKE = 0.5(m)v^2_f - 0.5(m)v^2_i.
  • Understanding of conservation of mechanical energy
  • Familiarity with gravitational potential energy (mgh)
  • Knowledge of kinetic energy formula (1/2mv^2)
  • Basic algebra for solving equations
  • Learn about the work-energy theorem and its applications
  • Study the effects of friction and air resistance on mechanical energy
  • Explore advanced topics in dynamics, such as non-conservative forces
  • Investigate real-world applications of energy conservation in physics
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of energy conservation principles in action.
pcandrepair
[SOLVED] Particle movement down a track
A particle of mass m = 6.60 kg is released from point A and slides on the frictionless track shown in the figure below. (ha = 5.20 m.)
(a) Determine the particle's speed at points B and C.
point B____________ m/s
point C ___________ m/s
(b) Determine the net work done by the gravitational force in moving the particle from A to C.
____________J
Ef - Ei
mgh + 1/2mv^2 = mgh + 1/2mv^2
I'm not seeing your attempt at the solution if you gave one. The particle probably starts from rest, but see if the problem specifies the initial velocity. If it starts at rest, you can eliminate one of the terms in your mechanical energy equation.
There is a picture attached but if you can't see it, point B is 3.2m and point C is 2m.
I see it now. Can you show me which term gets eliminated in your mechanical energy equation? If you can, you should be able to solve for the final speed of the particle at each point.
Since Vo = 0m/s wouldn't the 1/2mv^2 on the left side of the equation cancel and then I would just solve for my Vf on the right side
Remember that for energy to be conserved, your potential energy at the start must equal the kinetic energy at the end:
mgh = \frac{1}{2}mv^{2}
So you have the potential energy from point a to point b and the kinetic energy at point b. How can you use this relationship to find the velocity of the particle?
If the particle has an initial speed of zero, then the initial kinetic energy of the particle is zero. You'll only have one variable in the equation to solve for, which is v_f. Does that make sense?
so using mgHa = mgHb + 1/2mVf^2, i got 5.77m/s at point B.
I don't have a calculator right in front of me, but it's better that you understand how to get to the right answer than get the right answer. SticksandStones brought up a good point, which is the fact that we're using the conservation of energy here. The only reason you're able to set up the equation as you did was because we ignored friction and air resistance, and therefore mechanical energy was conserved. It looks like you set up the equation correctly, but can you show me what v_f is equal to in terms of variables? If you can, you ought to be able to plug in the values you have for the heights, the acceleration due to gravity and the mass, and find the final speed. Which you may have done on paper already.
My first answer was wrong cause i solved the formula wrong but i fixed it and found
Vf = sqrt(2(gHa - gHb))
which ended up to be 6.261 m/s.
That's the answer I arrived at as well. This is why it's good to set up the equation using variables before we start plugging stuff in. Post again if you have any more questions :)
To find part b which is the work done by the gravitational force from point a to c would I use... mgHa - mgHc = Kinetic energy = Work ?
Well, let's be clear about how we're defining work. The work-energy theorem tells us that the net work done on an object is equal to the objects change in kinetic energy, as long as the net force on the object is constant. Remember kinetic energy is defined as .5 times the mass of the object, times its speed squared. So we have:
W_{NET} = \Delta KE = .5(m)v^{2}_{f} -.5(m) v^{2}_{i}
You've already found the particles speed at C, so we need not deal with the heights any further.
  • · Replies 17 ·
  • · Replies 31 ·
