Pass/No Pass Class at Berkeley Question
  • Thread starter Thread starter berkdude022
    Berkeley Class
The discussion revolves around the implications of receiving a "no pass" grade in a one-unit pass/no pass seminar course at Berkeley, specifically within the context of graduate school applications. Participants explore the potential impact of this grade on future academic opportunities and share experiences regarding grade disputes with professors.
  • Meta-discussion
  • One participant expresses concern about how a "no pass" grade might affect their graduate school applications, suggesting it could look bad.
  • Another participant asserts that contacting the professor to change the grade may not be worthwhile and emphasizes the importance of maintaining good grades in other courses to mitigate the impact of this grade.
  • Some participants share experiences indicating that grade changes are more likely if there is a legitimate error or inconsistency in grading.
  • There is a discussion about the grading criteria of the course, with questions raised about whether attendance at optional seminars impacts the pass/no pass outcome.
  • One participant points out that attendance requirements were clearly stated in the syllabus, suggesting that failing to meet them weakens the case for a grade change.
  • Another participant notes that if the course is required for certification or professional development, retaking it may be necessary to earn the credit.
Participants express differing views on the significance of the "no pass" grade and the effectiveness of appealing to the professor. There is no consensus on whether contacting the professor would be beneficial or if the grade will have a lasting negative impact on graduate school applications.
Some participants highlight the importance of understanding the course requirements and the implications of attendance policies. There are unresolved questions about the grading criteria and the subjective nature of participation assessment in the course.
berkdude022
Hi everyone, so I goofed. I ended up taking a pass/no pass one unit course at berkeley called the berkeley connect program for physics. The class was designed for physics majors to collaborate and talk about physics and do activities and such. So I ended up not passing the course and I'm devastated. How bad will it look for grad school that I did not pass a simple one unit seminar course?
Pretty bad.
Great...Would it be worth my time then to contact the professor and try to get him to change my grade?
If I were the professor, I would find that very annoying and I would never change your grade. You can try, I guess. But you failed the course, just suck it up. Yes; it won't look good for grad school. No, it's not a disaster. If you get really good grades on other courses, good recommendation letters, nice research, etc. then this won't harm you much.
In my experience contacting a professor about a grade will result in a change if you have a legitimate argument. For example, if there was an error adding up marks on an exam, if a homework assignment appears not to have been given a grade when it was handed in, or if there appears to be inconsistent marking between your result and that of a colleague for the same answer.
Simply making an argument or a plea against a reasonable grade won't get you much and will essentially waste everyone's time.
So it's up to you to figure out if you have something legitimate to bring to the professor's attention that could increase your grade. Normally with smaller classes though, professors think long and hard about failing a student, at least in my experience.
Thanks for your guys' insight. I'm just hoping that it turns out to not be that big of a deal as I feel like a one unit class that doesn't pertain to my major requirements or prereqs will not have such a big impact later on.
Just curious, did you not go, or just not say anything in the class?
Didn't really talk in class, was shy
So how was the course graded? Were there actual grades, or just a pass/no pass grading scheme based on how much the professor thinks you contributed?
If it's the former, you're toast and should've brought it to his attention earlier, and only protest the grade if, like Choppy said, there was an error on the professor's part. If it's the latter, you might be able to make a solid case about how you contributed much more than he thinks you did.
For instance, if there was a lot of working in groups, maybe explain that you are too shy to speak in front of the class but contributed a lot to group projects and discussions. If you just sat there like a bump on a log, then you rightly failed.
It consisted of showing up to class and attending optional seminars and panels. I went to 3/8 of the panels and 4/5 of the classes. Still unsure why that constituted a np. But I emailed my professor and he's a genuinely nice person, so I'm hoping it was a mistake or something of the likes.
Come on. You didn't even show up to half the seminars. And it's the only thing that mattered for your grades you said. And you don't get why that's a fail? And you actually want to bring this up with the professor?
I said they were optional panels, if that's the reason I failed then I'll take the fail. But I feel like when they say "optional" then that is supposed to be the case.
Edit: I said the class consisted of those two.
Your argument is not that you actually did the work that should have entitled you to pass. It's that you didn't do the work and you don't like the consequences of not doing the work. I suspect that this argument will not be successful.
If you look at the online syllabus, it pretty clearly states "Berkeley Connect Students will be required to attend in person at least 50% of these events and to review the webcast if they cannot after the panels/seminar. Attendance will be taken!" You didn't go to 50% of them. That doesn't put you in a very strong position.
The fact that this class is essentially a gift of one credit doesn't help either. Both for the optics and for the chances of getting the grade changed.
Ah I see, I thought that they were considered optional as I had several conflicts with scheduling. Thanks for your information
Whether pass/NoPass or for a letter grade, if you still need the credit for some type of certification program or professional development program, you need to re-take the course and EARN the credit. The course still needs to be taken seriously.
When someone enrolls in a course, he should reasonably expect to be able to attend the activities assigned for the course. If he fairly judges ahead of time that he cannot reasonably attend what he needs, then a better choice is to postpone enrollment for another time.
  • · Replies 40 ·
  • · Replies 19 ·
