Passing a function as an argument in JavaScript
12 replies · 4K views
mindauggas
Code:
var square = function (x) {
  return x * x;
var cube = function (x) {
  return square * x;
This is my shot, its not right. Please indicate or suggest the correct answear. :)
mindauggas said:
Code:
  return x * x;
  return square * x;
No, it's not correct.
Code:
  return x * square(x);
Your thread title is misleading - you aren't using a function as an argument of another function. One function is calling another function. There's a difference.
In C or C++, you can use pointers to functions as arguments:
Code:
#include <stdio.h>
int f1xf2(int (*pf1)(int), int (*pf2)(int), int v){return(pf1(v) * pf2(v));}
int returnv(int v){return(v);};
int square(int v){return(f1xf2(returnv, returnv, v));}
int cube(int v){return(f1xf2(returnv, square, v));}
int quad(int v){return(f1xf2(square, square, v));}
int main(int argc, char ** argv)
    printf("square 2 = %3d\n", square(2));
    printf("cube   3 = %3d\n", cube(3));
    printf("quad   4 = %3d\n", quad(4));
    return(0);
I am confused...it always bugs me when people do not state what language they are talking about...sure, if I knew, I would recognize it; but often times I don't and I can still help, if I knew what to google.
So, the last post is C, sure...what's the first one, too? or is it matlab?
Once again, sorry. This time for abandoning my own topic. Like I said the programming language is JavaScript. And yes, thanks for pointing out, that the title is misleading: the function is indeed calling another function, not using it as an argument.
Returning to the problem. "When we call the square function as a part of the cube function, we still have to define the parameter associated with the square function" - a hint provided says thus. But how to write this assignment? I have never assigned a parameter for a function in the body of another function.
Any hints?
Should I assign a parameter the same way as a variable?
These kind of simple questions is something you don't need a forum for...you can play around with the language and its compiler/interpreter and test stuff at will...it does not cost any money and you are not going to break anything...play around, experiment!
...if, on the other hand, you have a major logic problem or a bug that you cannot find...then, the forum could help.
Any hints?
Can you state the original problem/assignment as it is given to you?
Using a function as an argument to another function would work like this:
Code:
var square = function(x) { return x * x; }
var cube = function(f,x) { return x * f(x); }
cube(square,2);
Though in this context I don't know why you'd want to pass in a function. I don't imagine you'd ever be swapping it out.
Code:
cube(square,2);
Thanks, this solved it.
Code:
  return x * x;
  return square(x) * x;
The answer to your question: it just for the sake of knowing how to use functions in all/allmost alt the ways legitimate.
I thought the idea was to use functions as parameters to other functions. I'm not sure if this syntax is correct for javascript, but it should look something like this:
Code:
var f1xf2 = function(f1, f2, x) {return f1(x) * f2(x);}
var returnx = function(x) {return x;}
var square = function(x) {return x * x;}
var cube = function(x) {return f1xf2(returnx, square, x);}
Code:
The original title probably mislead you, I apologize for this. the title should have stated that one function calls another function :)
