Path between fixed points in a logistic map
1 reply · 2K views
Decimal
Hello,
I have a question about period doubling and fixed points in the logistic map. Let's say I have a basic logistic map, ##f(x) = 4\lambda x(1-x)##. Let me then compare 1,2 and 4 iterations of this map on fixed points. I assume that ##\lambda## is large enough such that two period doublings have occurred, and a 4-cycle exists.
Now if ##\bar{x}## represents a fixed point for ##f^4(x)## (4 iterations of the map), then we have by definition, $$f(\bar{x}) = \bar{x}.$$ Obviously from this it follows that applying the function ##f^2(\bar{x})## twice should also take one back to point ##\bar{x}##, however this is where my confusion comes in. We are in a 4 cycle, so 4 different fixed points relative to $f^4$ exist. Let's call the fixed points closest to ##\bar{x}## (nearest neighbour) ##\bar{x}'##.
My lecture notes state that, ##f^2(\bar{x}) = \bar{x}'##. In other words, applying the map twice to a fixed point always takes one to the nearest neighbour. It is stated that this can also be extended to the general n-cycle case, where one would have, ##\bar{x}' = f^{2^{n-1}}(\bar{x})##.
I do not understand why these properties are true. There are 4 different fixed points, and I don't see why the path through these different points has to follow this form, since as I understand it all these points are practically equivalent. Why if I apply ##f^2## can't I go to a different point further away?
I suppose there is some connection between the nearest neighbours ##\bar{x}## and ##\bar{x}'##, but I am just not seeing it. Any help would be greatly appreciated!
Decimal said:
Hello,
Wouldn't ##\bar x## be a fixed point for ##f^4##? If ##\bar x## is a fixed point for ##f^4##, then it should be the case that ##f^4(\bar x) = \bar x##.
